I need DPF and EGR Off for Fiat Doblo with:
ECU: EDC16C39
HW: 0281012853
SW: 1037379905
Thanks in advance
ECU: EDC16C39
HW: 0281012853
SW: 1037379905
Thanks in advance
HI
DPF OFF, EGR OFF, CHECKSUM CORRECTED
PASS IN PM
REPORT BACK
THANKS
IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
atomantmk (24th February, 2020)
Engine don't start, it could be checksum problem because I have old file with only DPF Off and engine start.
no mate, you can't do full dpf egr off if not read by bdm
Now it's done, engine has started and we have found what the problem was.
Thanks for the time momogsm
Sent from my SNE-LX1 using Tapatalk
momogsm (24th February, 2020)
no mate you have not solved that problem because you can't do full dpf and dtc off if not read bdm. if you will have any sensor for dpf, engine light will come again
I have that problem with fiat bravo over obd read dpf off and after 1 day light comes on dpf filter but when u connect to diagnostic show no dtc... need bdm read to make dpf off with no limp mode ???
I think.Obd is partial read for this operation.
damjantuze (24th February, 2020)
hahahah sure, this ecu is very problem if not read bdm, obd is partial read. i did at least 70 ecu like this
DPF was done long time ago and i didn't saw check engine light or some other problems.
OBD read enough for DPF or EGR off ,no need BDM
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
mancioks (25th February, 2020)
