hello, i have this car
VW golf 7 - year 2016 and have this dtc. Can I help me? thanks.
Monday,24,February,2020,16:05:56:49504
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 HB HW: 04E 907 309 BH
Component and/or Version: R4 1.4l TFS H26 4418
Software Coding: 0119003223441D082000
Work Shop Code: WSC 00028 028 00031
ASAM Dataset: EV_ECM14TFS01104E906027HB 001006 (VW37)
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6BDFCFB98244901760-803E
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 36605 km
Date: 2019.07.28
Time: 20:40:56
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 12 °C
Intake air temperature: 14 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 13.311 V
Unlearning counter according OBD: 40
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 7
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 3
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Accelerator pedal travel: 0.00 %
Readiness: 1110 0001
Address 13: Auto Dist. Reg Labels: 3Q0-907-572.clb
Control Module Part Number: 5Q0 907 572 J HW: 3QF 907 572
Component and/or Version: ACC BOSCH MQB H10 0654
Software Coding: 2B00600111FFC728949C810560400600000000000000000000
Work Shop Code: WSC 00028 028 00026
ASAM Dataset: EV_ACCBOSCHVW416 002006 (VW37)
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 3E7936EDA1B6D5BF97-806A
3 Faults Found:
0101 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 36605 km
Date: 2019.07.28
Time: 20:43:23
Control Module temperature: 31 °C
Voltage terminal 15: 13.4 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_irreversible error
2119 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 36605 km
Date: 2019.07.28
Time: 20:43:23
2068 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 36605 km
Date: 2019.07.28
Time: 20:43:23
