Results 1 to 10 of 10
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Default Sharan starting problem...
    Hi, Sharan 2006 1.9TDI 85kw EDC15P+. Car run normally but week ago i hear alternator and stop charging battery, i replace it for new. Now car dont start. When i connecting battery,battery dont splutter.And dash looks like dont have power.But after ignition on dash have power.Impossible connect with diagnostic.After 3-5min. on power on start glow plug flashing.Some one have some advice? Thanks.
    Meat-Head's Avatar
    Look on top of battery for fuse links see if one loose or burnt
    Mar 2019
    EUROPE
    All checked kline not working on obd or any cable.cluster after power battery dont show any thing after 2nd possition cluster back to live.where is problem? Gnd,12v work good on ecu to obd.
    Meat-Head's Avatar
    Learning to speak English but i would guess the instrument cluster is fcuked and you need a new one
    it probably commuters from obd to the indain ecu. Gray/white pin 7
    Mar 2019
    EUROPE
    I think you mean.From obd 7 pin (kline) to ecu 16 pin(kline). I put multimeter to beep mode but nothing do.
    And not possible make diagnostic because when i connect vcds to car,ecu and other things dont respond.
    Mar 2019
    EUROPE
    Nobody ? ... Situation. Power battery.But on cluster i dont see mileage and clock.looks like no power.but after 2nd key possition cluster reset and i see time 0:00 and... .After remove key cluster again dead.And not possible start car. But car crank. Anybody?
    Mar 2019
    EUROPE
    Up...............
    dimitar's Avatar
    google translate????????
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Meat-Head's Avatar
    Quote Originally Posted by dimitar View Post
    Battery fcuked. You need a new one
    Nov 2015
    Behind the battery i have 3 connectors, check this connector first. Check the ground on battery, you have a small wire check it.
    This clusters don't have immo , your problem is on ecu.
    I put a photo sample to see what connector i talk.
    Trimis de pe al meu SM-G950F folosind Tapatalk
    If i help press the magic button
