Results 1 to 12 of 12
    super jumbe's Avatar
    Livingstone
    Default Vauxhall Combo 2014 any help with keydiy remote
    I need to know if there is a way to make a remote for Vauxhall Combo 2014 with keydiy remotes.
    smokey08's Avatar
    Essex, UK
    The xhorse ones work. Generate as fiat 500 Delphi
    Sent from my Pixel 3 using Tapatalk
  3. The Following 2 Users Say Thank You to smokey08 For This Useful Post:
    ghostrider72 (25th February, 2020), super jumbe (25th February, 2020)
    Apr 2016
    uk
    Use fiat Delphi remote...
  5. The Following User Says Thank You to comizelu For This Useful Post:
  6. #4
    autochei's Avatar
    Mar 2013
    romania
    cos thys car it s new doblo 93c86 and only with mini tool i could do thys remote
  7. The Following User Says Thank You to autochei For This Useful Post:
  8. #5
    ghostrider72's Avatar
    Jul 2012
    UK
    Didn’t know you can generate Delphi with XH
  9. #6
    Apr 2016
    uk
    Quote Originally Posted by ghostrider72 View Post
    You can generate Delphi and Marelli.
    The good thing is that are actually working!
  10. The Following 2 Users Say Thank You to comizelu For This Useful Post:
    ghostrider72 (26th February, 2020), p1et (26th February, 2020)
  11. #7
    Livingstone
    Thanks lads will have a go when customer comes back, do I need to precode or just programme direct with code?
  12. #8
    Apr 2016
    uk
    Quote Originally Posted by super jumbe View Post
    Combo is same as Fiat doblo.
    It's fiat Delphi system and Yes,you need to precode tp and remote, usual fiat key.
  13. #9
    Mar 2018
    UK
    Is it possible to use these XH FIAT remotes for Alfa Romeo ?
  14. #10
    Apr 2016
    uk
    Quote Originally Posted by Manta1600 View Post
    For Marelli and Delphi bsi,Yes..check the xhorse app.
  15. The Following User Says Thank You to comizelu For This Useful Post:
    Manta1600 (26th February, 2020)
  16. #11
    rob h's Avatar
    May 2011
    Not all of these, are fitted with a bsi that supports remote.
    They will have central locking,
    Dont think it is a config setting,
    And last i did, 2015 with delphi 93c86 .
  17. The Following 2 Users Say Thank You to rob h For This Useful Post:
    Manta1600 (26th February, 2020), super jumbe (26th February, 2020)
  18. #12
    Mar 2018
    UK
    Thanks found out - they puted Alfa Romeo like Romeo
