Hello, I need long coding for ABS module.
Monday,17,February,2020,13:57:45:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 9K - VW Caddy
Scan: 01 03 15 25 46 56
VIN: 9BWAB45UXEP155208
Address 01: Engine (J623-CFZA) Labels: None
Part No SW: 032 906 034 M HW: 03C 907 445 E
Component: CFZA-MM9GV H01 7205
Revision: --H01--- Serial number:
Coding: 01110016020400000000
Shop #: WSC 01530 935 00200
VCID: 1835D6B9EB888A9
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1S0 614 117 S HW: 1S0 614 117 S
Component: EBC 460 ABS H03 0212
Serial number: ABHE310
Coding: 00000000000000000000000000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Brake1ABSVWB23XTRW 001010
ROD: EV_Brake1ABSVWB23XTRW.rod
VCID: 3B7F2935B27E811
2 Faults Found:
0413 - Control Module Not Coded
U1013 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 10001001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 9
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
0415 - Coding Invalid
U10DA 00 [009] - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 9
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 15: Airbags (J234) Labels: None
Part No SW: 34D 959 655 HW: 34D 959 655
Component: AirbagVW20 005 0366
Serial number: 003K5M0KW4YB
Coding: 8800C00000000000000000C8000000000065
ASAM Dataset: EV_AirbaVW20SMEVW253 001110
ROD: EV_AirbaVW20SMEVW253.rod
VCID: F2E1441125B4809
4 Faults Found:
1111296 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Date: 2057.14.20
Time: 01:22:03
1111552 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Date: 2057.14.20
Time: 01:22:03
1110784 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Date: 2057.14.20
Time: 01:22:03
1111040 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Date: 2057.14.20
Time: 01:22:03
Address 25: Immobilizer (J334) Labels: None
Part No SW: 5U0 920 827 N HW: 5U0 920 827 N
Component: IMMO H08 0025
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: N/A
VCID: 448D52C9CF80FE9
No ASAM data for: "EV_Immo_UDS_VDD_RM09" ()
2 Faults Found:
9456128 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 13
Mileage: 4 km
Date: 2000.14.00
Time: 02:59:50
9456681 - ROD - Unknown Error Code
- 29 [008]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 68633 km
Date: 2057.14.20
Time: 00:00:07
Address 56: Radio (J503) Labels: None
Part No SW: 5U0 035 152 HW: 5U0 035 152
Component: MIBGLAM H12 0039
Revision: RA101000 Serial number: VWZ7Z2R1415752
Coding: 00000400020000
VCID: EAD15C710564489
4 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 159
Mileage: 60840 km
Time Indication: 0
Date: 2118.14.09
Time: 09:48:25
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 159
Mileage: 0 km
Time Indication: 0
00625 - Vehicle Speed Signal
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Time Indication: 0
Date: 2121.14.20
Time: 01:22:03
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 159
Mileage: 68633 km
Time Indication: 0
Date: 2121.14.20
Time: 01:22:03
End ---------------------------------------------------------------------
Thanks in advance
Ariel
