HC11E9 i think , code visible on 78h 79h example 1234
Why reading motorola? i think it is possible from serial
audiopoint (26th February, 2020), redzio55 (26th February, 2020), shooting (26th February, 2020)
Thx , sonices
I tried after the serial number but without success. Unless you have a better calc ?
B09898
For bp9898A-0618745 code is 7625
But i am confused about B09898 ?
Someone is already making this radio, so the code is changed. Does anyone have the memory contents for this model ( or approximate ) ?
Hi!
Friend! The code for SQR types canot be calculated serial. (unless someone has a database (unlikely)
You must read the 68HC11 Motorola.
If the boot process is successful and you only see FF, then HC11 is locked and its contents cannot be read. Then you need to another dump.
In this case, there is even code off content.
wbr
Hi Audio , that's why I'm asking if anyone will help with dump .
of course i can give it but you have to read the HC11 first because you can only reprogram it. If you can read it and its content is not FF then decoding is already easy ...
................... is FF , can you help ?
Hi!
Try this...
good luck
wbr
Thx , but it still displays nothing ...
Do you have any idea ?
I found this one but i dont know code
I'll try tomorrow and let you know....
