The steering lock module was repaired just 2 days ago (micro switches/relay). Car worked fine for 2 days but then dead, no ignition, remote lock/unlock doesn't work either. nothing. Only have 1 key, battery is brand new in it. Battery is brand new in the car too.
Faults are:
00166 access/start authorization switch e415 no signal/communication
01176 key no signal/communication
The key also gets stuck in unless I manually remove it using the emergency button. The remote central locking doesn't work either. Alarm just goes off.
Could it be the ignition switch or a further problem with the kessy module? Or key has lost programming some how?
