Results 1 to 9 of 9
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Default HOW CHANGE ECU BOSCH ME1.5.5 ??
    hi, i need help to put a used ecu in opel ASTRA G year 2001, i have carprog & opcom ,
    the ecu's old and new used one are the same both are :bosch ME1.5.5 hybride.
    i need to know the correct procedure to do it ?
    regards
    Sep 2009
    CARPROG read pin used and new ecu, dont reset carprog ecu ,opcom reset ecu and programing
  3. The Following User Says Thank You to janusz21 For This Useful Post:
    otojm (2nd March, 2020)
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by janusz21 View Post
    Sorry i don't understand well, what you mean by:"dont reset carprog ecu ,opcom reset ecu and programing" ??Please explain !regards
    Jun 2016
    To program used ecu u need 2 things. On the new second han ecu u need the pin to reset the ecu so that u can program it to your car. So with carprog u need to read pin of new ecu. Then u will use opcom to reset it. Then again u will use opcom to program this ecu into the vehicle under the cim or immobilizer or body control module depending on which opel u r working on. To program immobilizer function u need the pin of the original ecu from the vehicle. This again can be read from different modules again depending on which opel you r working on but it must be from vehicle. So u need carprog to read pin from old ecu and new ecu. New pin reset ecu. Old pin program ecu. Carprog can't do the programming. Opcom to reset new ecu and program new ecu. That's the best i can do. Hope it's clear now
  6. The Following 2 Users Say Thank You to Briankotze For This Useful Post:
    electronicar (14th September, 2024), otojm (29th February, 2020)
  7. #5
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Quote Originally Posted by Briankotze View Post
    hi thank you for helping me , unfortenantly i can't do a reset ecu with my clone opcom !! i don't understand why? regards
  8. #6
    Jun 2016
    There i can't help with explanation for opcom issue. I use clone fvdi for reset and reading pin. It works great on Opels
  9. The Following User Says Thank You to Briankotze For This Useful Post:
    otojm (6th March, 2020)
  10. #7
    Aug 2018
    East Pole
    Quote Originally Posted by otojm View Post
    Hello. Your opcom is a light clone. But... If you have astra g or corsa b, you just mount the spare ecu and go at immo. Hit program new ecu button and that will be all. Did it, tested it. No need carpass and stuff for that.
  11. The Following User Says Thank You to volorucinski For This Useful Post:
  12. #8
    Oct 2023
    Hello everyone,
    I have me1.5.5 for cloning and my question is if it is possible to read EEPROM and flash with MPPS V18 and write it to donor ECU?
    Then programming with OPCOM shouldn’t be carried out?
    ofc, if mpps reads eeprom and flash…
    anyone tried?
  13. #9
    Dobermann's Avatar
    Germany
    Quote Originally Posted by zrakoplovac View Post
    Hello everyone,
    anyone tried?
    hello,
    i think you need MPPS V22 >> V18 cant read eeprom
    i have both versions.
    cloning is no problem this ecu. if you have carprog you can read pin for reset
    this ecu is relatively simple.
    you not need to clone. if you can reset its ease to learn the ecu to car.
    br
    MM Flex Full , KESS3, KESS V2 and KTAG Original , ECM Titanium Genuine, CarProg V14, MPPS V22
