Results 1 to 2 of 2
    Sep 2016
    Panama
    Default ford ranger clear crash data
    Hi, need to clear crash data for ford ranger al54-14b321-ad
    I have two problem.
    I read first by can with iprog+ clone and suppose cleared file with can
    So I when install appear code u and others dtc with error additional and this car dont have this airbag. For example appear curtain and this car dont come with curtain.
    after I try to fix by read directly the mcu infineon xc2361b-40f by cpt, and I when put to clear file appear crash data with file by cpt
    So I cleared and I when to installed again in the car appear the same codes and file with crash data stored.
    I put files read by iprog+ clone and readed by cpt, so whon can help me.
    thanks advanced
    Jun 2016
    you mash with wrong tool on wrong time
    if you have CPT, you dont need to try othere tool first
    or if you really want to try, first save original crash data from module then try with other option
    only way to out from this situation is arrange working car and module with same configuration
    thanks and regards
