Results 1 to 12 of 12
    Dec 2010
    Red Wine earth
    Default Porsche Macan S 2015
    Hi freinds, i need help to change mileage for a porsche macan, 2015, i have read that eeprom inside is 95640
    car have 162.500kms
    i put 58.000 kms
    but now display show me error
    Can anyone help me?
    thank`s
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Post the original file.
    Regards,
    Landetos
    Live by the rules and die by the rules...
    Thank before you die...
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Sorry but your file is damaged or a not supported algorithm...
    Maybe if we try with the original file maybe then it can be decrypted...
    What tool you used for change?
    Quote Originally Posted by joaopereira View Post
    car have 162.500kms
    i put 58.000 kms
    Can anyone help me?
    thank`s
  4. The Following User Says Thank You to Landetos For This Useful Post:
    joaopereira (28th February, 2020)
    Dec 2010
    Red Wine earth
    hi Landetos
    thank you for response
    i used x-prog for read and write
    maybe the dump is corrupt
    the car work but give me error in display
    is possible fix the dump?
    thank you
    Apr 2018
    EU
    Didn't you save the original file?
    If you have it post it.
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
    brend's Avatar
    Oct 2015
    Same where
    Dump 100% ok.
    Just not all can do this algo.
    Ask help from drpeter or steveleo ​this guy can edit this 100%.
  8. The Following User Says Thank You to brend For This Useful Post:
    Drdiag (2nd March, 2020)
  9. #7
    Apr 2018
    EU
    I think his data is corrupt, loaded in Enigma and Elpro DP4 but both machine could not find encryption key.
  10. #8
    Dec 2010
    Red Wine earth
    hi friends the dump is original file
    the car start ok
    but show me error in display
    encryption key car don`t start maybe?
    or used other dump ....is possible?
    change vin?
    I compared other dumps and they are identical to mine ...
    I don't know what the problem will be
    thanks for help me
  11. #9
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Hi, you tried to upload the original file.
    Press Thanks and Reputation
  12. #10
    Jul 2016
    I tried your file and no decode. Strange. Is it really an untouched one?
  13. #11
    Dec 2010
    Red Wine earth
    yes i upload original file
    i read file x-prog
  14. #12
    Jul 2016
    i read file x-prog
    Hi, i will answer your question here as your PM box is full and it maybe helps other to not try it:
    You cannot use other dumps! The eep-dump is married to flash.
  15. The Following 2 Users Say Thank You to steveleo For This Useful Post:
    joaopereira (2nd March, 2020), rtbdiagnostic (16th March, 2020)
