We need to share our collective experience on this tool, what works good and what doesn't. Lets be real here...the Chinese sellers don't know shit.
If I helped you, please consider to rep + thanks me.
Aash00 (9th March, 2020), fuzz1 (3rd March, 2020), Gebalana ARJ (15th January, 2024)
There are clone and clone version of iprog. Some clones were reported to work just as good as the original or even better. Some others are just not worth. Mine has two pcb that has been filled with epoxy. You can't get access to any parts or try to repair it. Can't even try to make it work or repair if ever there is something wrong with it.
Some clones are sold saying never power it up with the DC supply and not to connect it via obd2 port else it will burn. Others have reported that there clone can or powered by dc source other than usb and can be connected to obd2 ports without problems.
Maybe people should tell us how much they paid for the good clones.
The clones are better cause you have newer software versions which are not available for the original version
I just got my clone the other day. They claim it's the V80 version.
I already went ahead and plugged in a 12v external power supply and it didn't blow up. I haven't cracked it open to take a look at which board color I have. What I can report is that my clone cost $ 89.90 before tax/shipping.
Yeah alot of people saying different things. I finally got this one https://www.aliexpress.com/item/3285...746b4c4dJV8ATN...with all the 7 adapters.
I might open the obd cable and desolder the power and ground cable on the end going to the iProg, so when I plug it in to do modules by obd, it should be safe.
Also my seller has some dumb instructions, would this not brick my iProg.Please don/'t power up IPROG by additional 12V Power.
Do not use OBD2 to connect to the car12V and 24V will not work (if you try it, it will give a burnt smell)
Must be linked to a computer
OBD2 line can only be connected to HONDA car
Other vehicle connections will burn Iprog equipment
Main steps to install V80 iProg Pro:
Step 1: Create a new folder in any convenient place on the disk. For example [iProgProSoftware]
Step 2: Unpack the archive into the created folder
Step 3: Run the program
Step 4: Select the menu item Help -> Check for Updates. Follow instructions
Step 5: Copy into your Scrips and Calculators folders your scripts and calculators, respectively
orx (8th October, 2020), rtbdiagnostic (15th September, 2020)
saludos ...e comprado varios clones ...mas de la mitad exelentes e podido modificar las calculadoras y anda super bien ...pero ortos que compre verdaderamente no cumple con lo que ofrecen para el costo vale ya que en materia de dash y fujitsu para mi concepto trabaja exelente solo hay que tener ciertos tips con todo gusto aportare mucho sobre el tema clones IPROG+
Just connected mine to obd2. It didn't burn, and still works. I think if you have the blue board with epoxy, you should be fine.
ASCM (1st January, 2021), Littey (11th January, 2021), rtbdiagnostic (19th December, 2020)
I have Iprog clone and i am really satisfied from it.
90% of dashboard and airbag calculations are good.
Today i was made Mazda Airbag unit trough OBD.
It was Infineon XC2361-56F.
GJR9-57K30B
Read
Clear Crash
Clear errors
Write
All trough OBD.
To Push Buttons,Thanks and Reputation is always best way to thanks!
cordero (9th April, 2021)
No,i didn't!
I ran the following to test my eeprom adpater on iprog and got the following. Can anyone have a look to tell me if it good or if there is something wrong with the adapter?
Тест установки питания ...
Установка: 2.6 В, Реально: 2.6 В. (0.0) OK 10B = 9.8 OK
Установка: 2.8 В, Реально: 2.7 В. (0.1) OK 10B = 9.6 OK
Установка: 2.9 В, Реально: 2.9 В. (0.0) OK 10B = 9.5 OK
Установка: 3.1 В, Реально: 3.0 В. (0.1) OK 10B = 9.4 OK
Установка: 3.4 В, Реально: 3.4 В. (0.1) OK 10B = 9.0 OK
Установка: 3.8 В, Реально: 3.7 В. (0.1) OK 10B = 9.0 OK
Установка: 4.3 В, Реально: 4.1 В. (0.2) Ошибка 10B = 8.6 OK
Установка: 5.0 В, Реально: 4.7 В. (0.3) Ошибка 10B = 8.1 OK
!!! Ошибки установки питания.
Тест шины данных...
VCC = 5.0 В: Ошибки: нет
VCC = 4.3 В: Ошибки: нет
VCC = 3.8 В: Ошибки: нет
VCC = 3.4 В: Ошибки: нет
VCC = 3.1 В: Ошибки: нет
VCC = 2.9 В: Ошибки: нет
VCC = 2.8 В: Ошибки: нет
VCC = 2.6 В: Ошибки: нет
>>>>>>>> Тест шины данных завершен...
Тест коммутации GND ...
>>>>>>> Тест коммутации GND завершен
Тест коммутации VCC ...
VCC = 5.0 В:
1-8: vcc = 951 OK
8-1: vcc = 982 OK
2-7: vcc = 982 OK
7-2: vcc = 982 OK
3-6: vcc = 982 OK
6-3: vcc = 982 OK
4-5: vcc = 982 OK
5-4: vcc = 982 OK
VCC = 4.3 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 988 OK
3-6: vcc = 988 OK
6-3: vcc = 988 OK
4-5: vcc = 988 OK
5-4: vcc = 988 OK
VCC = 3.8 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 988 OK
3-6: vcc = 988 OK
6-3: vcc = 988 OK
4-5: vcc = 982 OK
5-4: vcc = 982 OK
VCC = 3.4 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 982 OK
3-6: vcc = 982 OK
6-3: vcc = 982 OK
4-5: vcc = 982 OK
5-4: vcc = 982 OK
VCC = 3.1 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 988 OK
3-6: vcc = 982 OK
6-3: vcc = 982 OK
4-5: vcc = 982 OK
5-4: vcc = 982 OK
VCC = 2.9 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 982 OK
3-6: vcc = 988 OK
6-3: vcc = 982 OK
4-5: vcc = 988 OK
5-4: vcc = 988 OK
VCC = 2.8 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 982 OK
3-6: vcc = 982 OK
6-3: vcc = 988 OK
4-5: vcc = 988 OK
5-4: vcc = 988 OK
VCC = 2.6 В:
1-8: vcc = 988 OK
8-1: vcc = 988 OK
2-7: vcc = 988 OK
7-2: vcc = 982 OK
3-6: vcc = 988 OK
6-3: vcc = 988 OK
4-5: vcc = 988 OK
5-4: vcc = 988 OK
>>>>>>> Тест коммутации VCC завершен
I see all oks, and I tried google translate, but couldn't translate the other parts.
Yeah I've managed to read eeproms with this tool, but I wouldn't recommend it. Use the Eeprom adapter, pin #1 is where the lever is.
Anyone know why almost all scripts for airbag by obd work except for the KIA - HYUNDAI MOBIS CAN v1.05 script?
