Are the ukraine clones good quality?
Yes. Ask me in PM.
I bought it on ebay from user
iprog_plus with 'full tested' description.
First connection and bang and black smoke.
I wrote to seller about this issue and been told to receive power board witch never arrived.
It was bad cap in powersupply section.
Few mth later second cap blown.
A lot of scripts does not work and seller does not respond anymore.
Be aware.
fuzz1 (21st April, 2021), rtbdiagnostic (20th April, 2021)
better to just buy the china clone posted here thats without any resin etc and rework it yourself
you will then have a working clone
I purchased an IPROG+ to complete tasks that dealership equipment can't do.
Not fully tested it yet, but it does read ford 4D transponders, But not Vauxhall Insignia fobs ?
So far it has work perfectly on clearing cash data on RCM modules for 2009-2013 Transit connects via OBD. Something that Fords equipment can't do.
Having replaced IPC (Instrument Cluster) in a 2010 Transit Connect. All programmed in with Ford's equipment ok. Van starts & rund fine with everything working as it should. Although ODO readout incorrect. Something which again Ford's equipement won't allow correction.
I thought Iprog+ would do it ? Unfortunately it can't, not by OBD. Iprog can't find cluster on automatic ID ? Plus there's no option for 2009-2013 Transit Connects. Is there a script for this available ??
Here is my Iprog+ obviously a china clone with SN 1 - That will require sorting.
Not tried 12v power supply yet !
Does this power PCB require rework ??
Yes, you've got the same PCB as me (same silk screen). The power PCB won't stand a big current consumption with 12V external power supply, U2 would burn.
On main board I had a wrong value at R20, it should be written "513".
To avoid bad USB communication, increase R12 to 4.7kΩ, the default pullup is too strong and destroys the signal.
My clones: CanClip RLT2002, CDP Pro, OBDLink SX & now iProg+
PaulJeepman (3rd June, 2021)
Anyone been able to use iprog to read mcu successfully?
Anyone have MBBEKey master and working from latest V85? If can share.
Hello today I plugged 12 v adapter to my iprog and it burned how can I repair? Does anyone can help me
Sent from my 5033F using Tapatalk
