Page 19 of 33 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 494
  1. #271
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by fuzz1 View Post
    I can't believe the stupidity of those making clones. Using good parts would make the device reliable. They are fixing on getting the cheapest device not a reliable/working one.
    Typical of Chinese clones using cheap or incorrect parts or both
  2. The Following User Says Thank You to teerak2uk For This Useful Post:
    Jonatanfunes91 (10th June, 2021)
  3. #272
    Jonatanfunes91's Avatar
    Jun 2020
    Argentina
    what do you expect to do with the iprog by the way? what is your experience
    fuzz friend
    I need to cover odometer of VW / said renault ABS by obd2 and some brands of opel .. since with upa I can not do it .. they are the only car that I could not do ..
    if not, what do you recommend me friend?
    :wink
  4. #273
    wembleyhill's Avatar
    Feb 2009
    Quote Originally Posted by Jonatanfunes91 View Post
    fuzz friend
    you can't do (VW / said renault ABS by obd2) with iprog
    use buttons
  5. The Following User Says Thank You to wembleyhill For This Useful Post:
  6. #274
    Jun 2020
    Argentina
    Quote Originally Posted by wembleyhill View Post
    mmm thanks partner for the information I thought so .. mmm and what device do you advise me to do (ABS dacia / logan fluence etc ..)
    REnault
    Opel Meriva / Corsa
    VW G6 G5
    :wink
  7. #275
    fuzz1's Avatar
    Jul 2019
    Does anyone know what the 4.7 k ohm resistor that is needed to change to get the iprog + working with uart board goes to?I tried to change mine but damaged the pads so now wondering where to connect it to
  8. #276
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by PaulJeepman View Post
    I have replaced R20 with 51KΩ (513 0603) & R12 with 4.7kΩ (472 0603)
    After obtaining fw130sn, Updated via USB. Now I can change Serial No easily.
    I see that you replaced the resistor. Can you please tell me where the resistor is connected to on the board?I found two lines going from the resistor on the board. where does the connection line go to please?
    I tried to remove the epoxy on my board and it ripped the lines i can't follow them.
  9. #277
    fuzz1's Avatar
    Jul 2019
    Was wondering if supplying 5volts to pin 14 and 12 volts to pin 29 through an external power supply will get the iprog working.
    I know it's probably switching the output to those voltages at specific times or will probably destroy the capacitors.
  10. #278
    toyota123's Avatar
    Sep 2019
    ISTANBUL
    hi friend .. donch change if it's not nessecary ... mine is clone , and it works fine ...
  11. The Following User Says Thank You to toyota123 For This Useful Post:
    fuzz1 (15th June, 2021)
  12. #279
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by toyota123 View Post
    Unfortunately mine doesn't work. Carved out the epoxy to replace the resistor but only eeprom works. The other board no.
    I'm wondering if pins 14 and 29 can be supplied with constant voltages. Ok with the addition of pull up resistors
  13. #280
    May 2021
    Is there a simple way to test which adapters work on my Iprog clone? The revision of my board is 2020.12.22, no glue or epoxy.
    And is it safe to supply 12V to the board?
    the EEPROM adapter works.
  14. #281
    fuzz1's Avatar
    Jul 2019
    Not advisable to connect 12V
    Not really necessary
    Check if it passes the tests. There are scripts in the iprog but you will have to make some simple board or use a breadboard
  15. #282
    May 2021
    Thanks! I found it. I'll get some diodes and test it.
    Was your test OK? Did you have to change D4 diode or R12 resistor?
  16. #283
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by elektoni View Post
    Nah mine failed.
    Covered with epoxy. So heated it and removed the power board. Now waiting for components to try and fix it
  17. #284
    May 2021
    I changed the R12 resistor to 4.7k, the previous one was 1.5k. I think it helped with some communication problems
    Any help on this issue? I am trying to read Motorola MCU 912DG128ACF. I have connected all the 4 wires correctly to the IC and I lifted the RESET leg. When I try to read EEPROM or FLASH the progress bar stops at 12% and nothing else happens. The log says "registered = E01BE4C0", "Errors= 40". I am using script 68HC912DG128A
  18. #285
    fuzz1's Avatar
    Jul 2019
    Iprog v86 out
    Anyone can share it?
    What's new in it?
