Page 29 of 33 FirstFirst ... 1924252627282930313233 LastLast
Results 421 to 435 of 494
  1. #421
    May 2020
    RUS
    New script.
  2. #422
    kosta89's Avatar
    May 2018
    Georgia
    Hello, need script for chine iprog to read write ford and mazda srs module with tricore, by can or uart.(not for free)
  3. #423
    al70's Avatar
    Nov 2017
    Éire
    does this help ?
  4. The Following 11 Users Say Thank You to al70 For This Useful Post:
    asliyucegsm (7th January, 2024), Col19 (8th January, 2023), Darek90 (5th October, 2022), foulou0238 (30th November, 2024), fuzz1 (30th September, 2022), hoangtu (16th October, 2022), lounadak (12th October, 2023), richizer (26th May, 2024), Rotor (25th October, 2023), rtbdiagnostic (30th September, 2022), Willinickersen (30th September, 2022)
  5. #424
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by foskr View Post
    New script.
    You sharing the new scripts? What are they?
  6. #425
    Junior Member vova1970's Avatar
    Dec 2016
  7. #426
    HeXeN's Avatar
    Mar 2015
    What version of iprog clone would you reccomend? v87?
    I have many original tools but thinking to buy it as a backup
    Maybe someone can help me
  8. #427
    fuzz1's Avatar
    Jul 2019
    [QUOTE=HeXeN;4434826]What version of iprog clone would you reccomend? v87?
    Maybe someone can help me[/QUOTE
    The clones are almost same. Its not version dependent but rather hardware dependent.
  9. #428
    Nov 2020
    [QUOTE=Smithboy123;4045928]
    Quote Originally Posted by Alex77ae View Post
    I just bought the authentic one. I want to compare with the clones. Whats a good one you would recommend. I see a lot of them on ebay claiming different versions.[/QUOTE
    Hi can i ask mate have you the Emvima IDE software that can create scripts for iprog as only those who have original device can get it. I be very happy if you can give me this please thanks
    emvima IDE is not avaliable from (emvima) OE site , to get it you will need to sign up too the iprog.pro site and then ask the developer for it.
  10. #429
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    my iprog reads 93c56 chip from Hilux OK when writing it writes in the last offset 00F0 'FF FF' instead it should be '00 00" causing the display mileage to flash
    Any suggestions see my attached files to compare
    'If I helped, please click Thanks +Reputation.. !'
  11. #430
    May 2015
    My Tool Room
    Howzit
    Need advice on these 2018 Ford Figo Aspire clusters with R5F10DPJJ processor
    Can I perhaps load a complete new flash with lower mileage via obd and then change to required mileage
    It seems that X300m can read the file but no luck lowering mileage but it can increase the mileage
    Anybody that can share a file that i can test if this method could work
    I-prog perhaps works via obd on these cluster anybody had any success ?
  12. #431
    May 2015
    My Tool Room
    this is the error i get on the figo renesas cluster with iprog clone
    Division by zero
    Press Ok to ignore and risk data corruption
  13. #432
    Dec 2016
    What name of script?
  14. #433
    Feb 2019
    obrigado!!
  15. #434
    Member vanders's Avatar
    Nov 2018
    Costa Blanca - Spain
    Following this thread.. and curious if someone have this iprog V87 with the "gold" rfid adapter working fully..
    reading PCF 7936 transponder and only the first line shows up.. with the "blue" rfid adapter no transponder found message..
    Already changed the R12 resistor for 4.7 k.. for the rest nothing changed.. see attachments.
  16. #435
    meteor80's Avatar
    Subaru H8SX 1726
    Done yesterday.
    Read via OBD, write by UART.
    Not very simple but works fine.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  17. The Following User Says Thank You to meteor80 For This Useful Post:
    rtbdiagnostic (10th March, 2023)
