Page 2 of 33 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 481
  1. #16
    ReverseFlash's Avatar
    Jan 2017
    North America
    Quote Originally Posted by svl0r View Post
    Did you tick the 3-11 pin check box? Also to my previous comment. I opened mine also. I didn't see any eproxy or don't recall. Is it on the whole board or a certain IC?
    The entire board is covered, and this was tested on bench and in car. iProg still works good. Only script that i tested that does not work is the Hyundai Mobis script
    If I helped you, please consider to rep + thanks me.
  2. #17
    fuzz1's Avatar
    Jul 2019
    Has anyone been able to use it to read any keys?
  3. #18
    agstur's Avatar
    Aug 2012
    Plovdiv
    Today I tried to read VW Caddy with 908az60 processor via OBD and Kline. Both didn't work. I read it with Carprog for 3sec. trough Kline.
    To Push Buttons,Thanks and Reputation is always best way to thanks!
  4. #19
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by agstur View Post
    Do you mean you can read the eeprom via k line using car prog?
  5. #20
    agstur's Avatar
    Aug 2012
    Plovdiv
    Yes I read it and i wrote it with Carprog on Bench trough Kline.
    The SRS unit was 6Q0 909 605 AH-5WK43351.
    The correction of the file i made with AST
  6. The Following User Says Thank You to agstur For This Useful Post:
    fuzz1 (17th June, 2021)
  7. #21
    Jan 2020
    Hello. I bought iprog clone 4 months ago from china. After connecting to 12 volts, it burned. I bought another one to test what was wrong. Replace all SMD capacitors to 227 C and everything works and does not heat. The cause of burning OBD cable is also too small capacitor. Good luckip2.jpgip3.jpgip4.jpg
  8. The Following 2 Users Say Thank You to marcinmalmo For This Useful Post:
    fuzz1 (15th June, 2021), laurentiudania (29th April, 2021)
  9. #22
    fuzz1's Avatar
    Jul 2019
    Maybe with all the knowledge you acquired you can even manufacture your own iprog and make it better. Just wondering if anyone can get a circuit diagram for this programmer.
    The one that i bought was shipped from some gulf country. It has a solid white epoxy in between the two pcb. Too difficult to separate it.
    What capacitor did you replace to be able to externally power it up without burning it? Did you use positive for the inner plug?
  10. #23
    Jan 2020
    Yes, I connect my Iprog to 12 volts and it works. OBD cable also. in the photo I have marked the capacitors that should be replaced (the red marks ones have those that burn most often. those marked in green should be replaced with 22uf C or D capacitors, if you do not have smd capacitors, you can solder ordinary electrolytic capacitors. for example, figure 2 (how to replace 2 capacitors per one) in the OBD cable there is only one capacitor, it should also be replaced if it is 106 A or 477 A (A = 10 V) B = 12 V, C = 16 V. ... 10 V and 12 V in the supply line is not enough for our precise Chinese power supplies Tolerance sometimes up to 15% especially those for half USD. Good lockaaa1111.jpgaaaa2222.jpg
  11. The Following 12 Users Say Thank You to marcinmalmo For This Useful Post:
    ampibali (21st November, 2022), ASCM (1st January, 2021), brodaty (27th January, 2022), claudio35 (27th August, 2020), Col19 (6th February, 2021), fuzz1 (26th March, 2020), galaxy0634 (24th May, 2021), kvalentino (22nd November, 2023), laurentiudania (29th April, 2021), mobilni (23rd January, 2021), pezao (22nd October, 2020), rtbdiagnostic (23rd September, 2020)
  12. #24
    fuzz1's Avatar
    Jul 2019
    Has anyone heard about Iprog+ with serial number 777?
    There is supposedly a script to change the serial number to 777.
    Anyone got it?
    http://www.fvdiobd.com/new-iprog-plu...han-iprog.html
    It is supposedly better
  13. #25
    Jan 2017
    North America
    Yeah I saw that one after I bought mine. I wonder if anyone knows how to convert to that version?
  14. #26
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by ReverseFlash View Post
    Seems there is a dongle with the new one. An emulator will probably be needed.
    Crazy the clone is getting additional protection.
  15. #27
    slick_dick's Avatar
    Essex
    any one tried the honda spc airbag resseter, i always get ecu not recognised. using the kline adapter with iprog and 3 wires to ecu, anything else??
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  16. #28
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by slick_dick View Post
    I tried all the Honda resetter via k line. Read the crash cleared it but then put it in the car and the airbag light still on. Frustrating iprog
  17. The Following User Says Thank You to fuzz1 For This Useful Post:
    slick_dick (2nd April, 2020)
  18. #29
    fuzz1's Avatar
    Jul 2019
    Does anyone know what is the utility of changing the serial number of the iprog? Apart from serial 777c that is
  19. #30
    agstur's Avatar
    Aug 2012
    Plovdiv
    Hello! I just read and wrote this SRS Unit from a Volvo S80 with Iprog+.
    It is P30798509 with Motorola 9S12XDT256.
    Everything worked fine, but I had to lift Reset pin.
    I read both Eеprom and Flash without any problems!
    This are the both Eeproms,with crash and cleared!Best Regards!
  20. The Following 6 Users Say Thank You to agstur For This Useful Post:
    albertros (4th April, 2020), ASCM (1st January, 2021), fuzz1 (4th April, 2020), laurentiudania (29th April, 2021), ruben baez (26th August, 2021), Yhoni (20th December, 2021)
