Page 33 of 33 FirstFirst ... 23282930313233
Results 481 to 494 of 494
  1. #481
    hi here you have how to connect to clio4 airbag ecu with spc560 processor. If you wont you can ad this script to renault spc folder.
    If I helped you, please consider to rep + thanks me
  2. The Following 2 Users Say Thank You to carbyvw For This Useful Post:
    art64 (28th February, 2025), s928s24u (6th March, 2024)
  3. #482
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all.
    Today my IPROG ( china original ) died. USB device not recognized. Flashed it with 1.30.s.n0001 bin file. Now it gets recognized by PC and I can use it 2-3 times and then again no usb recognition. Does some one have other file for 91SAM7S256, no other idea what to do? Power board was reworked long time ago and it was working good till today.
  4. The Following User Says Thank You to PSAcars For This Useful Post:
    solsol (14th March, 2025)
  5. #483
    Apr 2024
    Good afternoon Help is needed.There was no external power supply.
    I made a power board. But I have a mistake I can not understand. Where to look for the problem.
    Start test
    --- Тест VCC = 3V ---
    ADC0 (контакт 41) = 3.1 V. OK
    --- Тест VCC = 5V ---
    ADC0 (контакт 41) = 5.0 V. OK
    --- Тест 10/12V ---
    Uвых = 10V
    ADC2 (контакт 43) = 9.7 V. OK
    ADC3 (контакт 44) = 0.0 V. Error
    Uвых = 12V
    ADC2 (контакт 43) = 11.6 V. OK
    --- External power test--
    Выключено: 0.0 V. OK
    Включено: 5.0 V. OK
    --- Тест выводов ---
    PORTD.1 (вывод 6): OK.
    PORTB.5 (вывод 3): OK
    Тест завершен. Ошибок: 2
    Removed the 100 Ohm resistor from the plug
    Start test
    --- Тест 10/12V ---
    Uвых = 10V
    ADC3 (контакт 44) = 9.1 V. Error
    Uвых = 12V
    ADC3 (контакт 44) = 10.8 V. Error
    --- External power test ---
    Включено: 5.0 V. OK
    PORTE.0 (вывод 7): OK.
    What could be the problem?
  6. #484
    Mar 2024
    Quote Originally Posted by marcinmalmo View Post
    Yes, I connect my Iprog to 12 volts and it works. OBD cable also. in the photo I have marked the capacitors that should be replaced (the red marks ones have those that burn most often. those marked in green should be replaced with 22uf C or D capacitors, if you do not have smd capacitors, you can solder ordinary electrolytic capacitors. for example, figure 2 (how to replace 2 capacitors per one) in the OBD cable there is only one capacitor, it should also be replaced if it is 106 A or 477 A (A = 10 V) B = 12 V, C = 16 V. ... 10 V and 12 V in the supply line is not enough for our precise Chinese power supplies Tolerance sometimes up to 15% especially those for half USD. Good lockAttachment 702235Attachment 702236
    I check the power pcb and i found some components missing is Normal. The seller said that it'll never burned
  7. #485
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Missing component = half working power board, no 10v switching to 12v no good 5v. You need to rework power board to full elements on PCB.
  8. #486
    fuzz1's Avatar
    Jul 2019
    The iprog can be powered in two ways. Usb and external 12 volts. If you have incomplete power board then only usb power will work. Post photo of the board
  9. #487
    Jul 2016
    Hello. everyone. Has anyone tried to read Bcm2 (audi) via Iprog? What is the pinout and what adapter do I need to use?
  10. #488
    Mar 2024
    Hi . Any one try v89 iprog software with clone ?
  11. #489
    Mar 2024
    Bulgaria
    hi how to connect with Jlink to recovery ? I can't found good pinout to connect like video https://www.youtube.com/watch?v=GE-CwaXJAFk
  12. #490
    Jan 2022
    Screenshot_20250206_205037_Bob Shop.jpgScreenshot_20250206_205104_Bob Shop.jpg
    Hi all! What is the difference between these two iprog clones? They are both from the same seller and more or less the same price.
  13. #491
    Sep 2024
    SoCal
    Hello all,
    I have an Iprogpro+ clone and 06 MB CLK 500 /all keys lost. The car is is mine, about to be the wife's. Can someone walk me through the procedure of pulling the info to make a new key for this car using either the EIS which is a C209-ZGW 290315 04/S
    Thanks in advance
  14. #492
    Jan 2019
    Default Iprog Jtag pinout
    Here you go, buddy.IMG-20230121-125243-HDR.jpg And the video on your link is incomplete, it doesn't show that pin 55 needs to be short to 3.3V to erase CPU.
  15. #493
    Feb 2025
    Philippines
    This maybe so late since today is year 2025, but thanks to this, I was able to change my SN
  16. #494
    Feb 2017
    Italy
    Hi friends, are there Iprog scripts for Infineon tricore Aurix TC2XXX JTAG?
