Hello!
I read it with this adapter for Iprog+. When you choose to read MC9S12XDT256 from the menu, there is pinout!Only one different, that you need to lift RESET pin.
I connect only
Gnd
+5v
Reset
BKGD
Hello!
I connect only
Gnd
+5v
Reset
BKGD
To Push Buttons,Thanks and Reputation is always best way to thanks!
al70 (9th January, 2021), albertros (4th April, 2020), aty74 (20th November, 2023), laurentiudania (29th April, 2021)
Hello to all. About fuzz1 requesting schematic of iprog. We have it here on DK.
ASCM (1st January, 2021), aty74 (20th November, 2023), Blaxky (17th October, 2020), Briankotze (5th April, 2020), Col19 (6th February, 2021), credoline (11th March, 2021), Darek90 (26th April, 2020), dualboot (5th April, 2021), eeprom241 (21st December, 2020), electronicdeivi (3rd September, 2021), fuzz1 (4th April, 2020), Gebalana ARJ (14th January, 2024), ggaltstart (23rd October, 2023), habbou (26th May, 2020), Jacky Sop (13th November, 2023), JMAILLIER (17th February, 2024), laurentiudania (29th April, 2021), lumetan (11th January, 2024), mario066 (5th January, 2021), nil (1st February, 2021), paradajz (3rd July, 2021), polymeca (10th August, 2023), ProblemChild (5th February, 2021), Ray6K (12th March, 2021), RevBernie (6th May, 2021), Rotor (23rd April, 2020), rumensivanov (30th April, 2021), serikpay (25th November, 2022), slick_dick (4th April, 2020), SpeedyL (11th January, 2023), svallecilla (13th February, 2023), TERNOCOD (3rd January, 2021), tx-mafia (28th December, 2023)
Here is version 84
However i have not found anything new from it. Maybe an improvement in the calculator.
Please check an report.
https://mega.nz/file/gZp2mQZT#k3X5Te...zJgc-W-4D-XZUo
No password
Here are the repair schemes for Chinese Iprog.
Friends, did anyone try to order a fee here for repairing Chinese shit flooded with a compound? I built myself a programmer on this board from scratch, it works even better than the original. Not advertising.
By the way, they can make firmware on any Syrian number for free, if you ask.
https://www.ebay.com/itm/23355926412...84.m1555.l2649
and video
https://www.youtube.com/watch?v=7oBf0qrASBA
Bluueelfer (7th April, 2023), Col19 (6th February, 2021), Darek90 (26th April, 2020), electronicdeivi (3rd September, 2021), fuzz1 (18th April, 2020), ggaltstart (23rd October, 2023), kroy0402 (17th November, 2020), Louislesinge (22nd June, 2021), maremuruk (23rd April, 2022), mariantv (18th January, 2022), meansure (18th February, 2021), mr10 (2nd May, 2022), rtbdiagnostic (23rd September, 2020)
Can you explain why you say it works even better? What was better?
There voltage errors are fixed, the DC-DC converter is configured. Due to the fact that everything is on the same board, it is impossible for the PLS connector to have poor contact.There are many benefits. J-Link connector is output and signed on the board. There are also additional buttons for erasing the processor and firmware using the utility for the built-in loader "Sam-ba" also made.Completely repeats the Chinese board in size and can be installed in the Chinese case instead of the blue non-working board.
tehnosoftex (9th April, 2023)
does anyone tried already to read a TOYOTA YARIS AIRBAG MODULE 89170-ODA30 by bench or in car by obd2?
always communication error,, i did read by bench using obd2 and by obd2 in car...
if you think i helped youkindly press REP+THANKS button
Can the board be used to connect to any car via obd port? The Chinese one can only be connected to Honda without causing damage.
Can a power connection be connected to the board?
Yes, it works fine with external power, I connected an external 12V to power the dashboard on the table.
By OBD2 it works the same way as the original for all cars that are declared in the program. Soon they will have all the adapters of the correct assembly.
There will be an adapter for OBD2, RFID for keys - tuned to 2 frequencies with auto-switch, EEPROM and BDM / UART.
Anyone who can thank, gets even moreAnyone who can thank, gets even more
In order for the script to change the number to make it work, you need to update the iprog firmware via usb with iprog v6.
Can anyone share the program and flash files iprog?
I have scripts from nr.sn 777 and I wanted to check if they work better than Chinese ones.
Hey. I have firmware and programs for different serial numbers. If you need help with the firmware, write. I will be happy to help.
I apologize for the crooked translation.
I try to write more clearly.
This is my first iprog in the photo. Then I programmed it under 35 serial number.
He was still on two circuit boards.
In the photo, for example, I programmed serial number 35.
Can you help me how to program serial number?
I have sn45(Ukraine) and sn1(China)
I hope change sn45 to sn1
thank you.
