Page 5 of 33 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 494
  1. #61
    Feb 2016
    Россия. Санкт-Пе&#1090
    try different. 1 19 35 45 777
    Anyone who can thank, gets even more
  2. #62
    ReverseFlash's Avatar
    Jan 2017
    North America
    Anyone know the password to change iprog serial number.
    If I helped you, please consider to rep + thanks me.
  3. #63
    May 2016
    Quote Originally Posted by mihei View Post
    I tried 1 19 2048 325 35 45 49339 55 777, it doesn't work.
  4. #64
    Feb 2016
    [QUOTE = naprawa5; 3851773] Я пробовал 1 19 2048 325 35 45 49339 55 777, это не работает. [/ QUOTE]
    Try in the binary editor to see which serial number the script belongs to, and we will do the firmware for the same serial number.
    BUT IF YOU ARE PROGRAMMING THE MCU WITH A NEW FIRMWARE YOU WILL NOT BE ABLE TO CHANGE THE SERIAL NUMBERS DIRECTLY FROM THE PROGRAM, ACCEPT THIS NOTICE.
  5. The Following User Says Thank You to mihei For This Useful Post:
    mariantv (18th January, 2022)
  6. #65
    Feb 2016
    Only 10 PCBs available for Iprog assembly. You can also understaff parts for assembly. Who likes to do this on their own and does not want to overpay for the original programmer, this is your option!
    There are also assembled devices that personally pass all the checks personally by me before sending!
    Additional photos and video reports. Assembly instructions with photos and quality software.
    Write in person.
  7. The Following User Says Thank You to mihei For This Useful Post:
    Col19 (6th February, 2021)
  8. #66
    Rotor's Avatar
    Hello,,
    This is FULL Iprog+ program version V84,(mega) with scripts, calculators and other files,
    just extract the Winrar folder to your C:/ and run it.
    Rar 954Mb is protected with
    a password already included with the link.
    It works with my Iprog+ SN#1, but use it on your risk,
    i take no responsibility if something goes wrong.
    If this file help you please press "Tanks" and "Rate".
    (i will post more scripts later)
  9. The Following 48 Users Say Thank You to Rotor For This Useful Post:
    Adamdad (25th June, 2023), Adysyncro (5th January, 2023), asliyucegsm (1st January, 2024), autocargo (13th July, 2020), Boggdan (16th September, 2022), boxsport (25th May, 2020), byFritz (21st December, 2021), cardiagprofi (22nd April, 2020), carsoftobd (31st August, 2020), Col19 (6th February, 2021), dawidhubert (18th October, 2020), dragon100 (22nd April, 2020), eeprom241 (17th June, 2023), emiter66 (4th June, 2022), enigmaelectroni (30th March, 2021), freerefill (30th April, 2020), geeroam (30th May, 2020), gomarota (26th April, 2020), hudy26 (24th April, 2020), joejam (22nd April, 2020), Jonatanfunes91 (7th June, 2021), Jozua (21st April, 2024), ledong (29th September, 2021), lion0304 (22nd April, 2020), LuckkyLuke (20th May, 2020), maremuruk (23rd April, 2022), maryna (30th April, 2021), mikelelere (29th May, 2021), mobilni (23rd January, 2021), MOBILTRONIC (2nd March, 2022), moldo25 (13th April, 2024), nacar (27th May, 2023), PierreTheron (24th September, 2021), popescuvali (22nd November, 2021), r3aperx (17th June, 2022), rdu04 (11th May, 2023), rtbdiagnostic (17th August, 2020), rumensivanov (30th April, 2021), rybenz (23rd May, 2020), s928s24u (7th March, 2024), sep382 (6th April, 2021), stanislav georgiev (7th May, 2023), svallecilla (13th February, 2023), TERNOCOD (3rd January, 2021), tx-mafia (28th December, 2023), xmtmx (20th April, 2025)
  10. #67
    May 2016
    Can you make a script to change sn to 325?
  11. #68
    Feb 2016
    Вы можете сделать скрипт, но он не будет работать на китайском Iprog. Я могу сделать прошивку только Mcu, для 325 S / N
  12. #69
    Feb 2016
    [QUOTE = naprawa5; 3852099]
    Можете ли вы сделать скрипт для замены sn на 325? [/ QUOTE]
    In general, this script has a 777 serial number.
  13. #70
    May 2016
    Does not work with 777.
  14. #71
    Feb 2016
    Quote Originally Posted by naprawa5 View Post
    https://youtu.be/45n7naFVXrA
    Try other programs. Some Chinese builds do not work.
  15. #72
    Jan 2017
    North America
    Does anyone know why the Hyundai Mobis script doesn't work? It is attached. It gives me authentication error.
  16. #73
    May 2016
    I checked all programs, it doesn't work.
    Can you share your v82 program?
  17. #74
    Rotor's Avatar
    In attach you have link for several versions of Iprog collected
    from the web, try it and report, link and pass included.
    43-45-48-55
    68-69-75-76
    77-80-82
    83-84
    (you may notice that some versions have the same exact size)
    i take no responsibility if it damage your programmer.
    Please press "Tanks" & "Rate"=(Reputation) if this help you.
  18. The Following 10 Users Say Thank You to Rotor For This Useful Post:
    Charlieb1 (30th September, 2021), Col19 (6th February, 2021), Jonatanfunes91 (7th June, 2021), maremuruk (29th April, 2022), mobilni (23rd January, 2021), rtbdiagnostic (17th August, 2020), s928s24u (7th March, 2024), serikpay (25th November, 2022), svallecilla (13th February, 2023), Tolik48 (30th October, 2021)
  19. #75
    May 2016
    Quote Originally Posted by Rotor View Post
    43-45-48-55
    68-69-75-76
    77-80-82
    83-84
    I have these programs, it doesn't work.
