Page 6 of 33 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 494
  1. #76
    gomarota's Avatar
    can anyone tellme why i cannot read with obd2 plug ford focus dashboard odo?
    it says can adapter but i want to do in car...
    LOVE DK!
  2. #77
    May 2016
    Quote Originally Posted by gomarota View Post
    Use automatic id read.
    Then choose dash.
    https://www.youtube.com/watch?v=FxEm3xitIJ8
  3. The Following User Says Thank You to naprawa5 For This Useful Post:
    laurentiudania (29th April, 2021)
  4. #78
    gomarota's Avatar
    Quote Originally Posted by naprawa5 View Post
    Then choose dash.
    i tried it and says error, car is ford smax 2007
    LOVE DK!
  5. #79
    May 2016
    Ford DMax ?????
  6. #80
    gomarota's Avatar
    LOVE DK!
  7. #81
    May 2011
    UK
    Can anyone help me with a iprog Iam trying to change my serial to 777 with no luck has any one got the sn777 script file to change?. Any help would me appreciated.
  8. #82
    May 2016
    Changing sn to any works well.
  9. The Following 2 Users Say Thank You to naprawa5 For This Useful Post:
    rtbdiagnostic (19th August, 2020), xlv600 (12th February, 2021)
  10. #83
    May 2020
    RUS
    RFID_1.jpgIf the RFID doesn't work
  11. The Following 4 Users Say Thank You to foskr For This Useful Post:
    art64 (2nd March, 2025), Col19 (6th February, 2021), enigmaelectroni (22nd June, 2022), laurentiudania (29th April, 2021)
  12. #84
    May 2020
    RUS
  13. #85
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by foskr View Post
    Thanks for your post. However the picture isn't clear. Can't figure out what needs to be changed
  14. The Following User Says Thank You to fuzz1 For This Useful Post:
    habbou (26th May, 2020)
  15. #86
    May 2020
    RUS
    Quote Originally Posted by fuzz1 View Post
    R4,R5 100r. R8,R9 4.7r. the rest is as in the photo.
  16. The Following 4 Users Say Thank You to foskr For This Useful Post:
    al70 (11th January, 2021), Col19 (6th February, 2021), fuzz1 (12th June, 2022), laurentiudania (29th April, 2021)
  17. #87
    Default TOYOTA DENSO RENESAS 98221CA010
    Trying to clear TOYOTA DENSO RENESAS 98221CA010
    never used iprog before, i can connect and read DTC's but cant do anything else.
    i'm connected in can mode, log below....any help appreciated
    POWER ON...CAN_ADAPTER OK....INIT OK.
    READ ECU INFO... OK.
    PART NUMBER ECU: 89170 - CA010
    READ DTC
    INITIALIZATION... OK.
    READ... OK.
    1618 Front airbag sensor error LH
    1688 Unknown code or not active
    1801 Open circuit driver airbag
    1806 Open circuit passenger airbag
    1901 Open circuit P/T AB RH
    1986 Unknown code or not active
    1861 Open circuit knee AB driver side
    1821 Open circuit side airbag RH
    1888 LF/Driver head restraint rearward switch circuit high
    1831 Open circuit shield airbag RH
    1836 Open circuit shield airbag LH
    1660 Passenger AB active mode indicator
    16D1 Unknown code or not active
    1623 Unknown code or not active
    1628 Unknown code or not active
    END !
    READING FLASH PROCEDURE
    INITIALIZATION... ERROR... 254 CHECK THE POWER AND CONNECTION.
  18. #88
    Aug 2008
    are you kidding?
    the pic is very clear and all parts to replace are clearly marked
    i dont get what you cant see
  19. #89
    Oct 2015
    even though its a toyota the part num CA is still a SUBARU thats why you will never be able to read write it, the obd function only works on ALL TOYOTAS and very small amount of subarus
    just do it old fashin way solder 6 wires and flash
  20. #90
    Quote Originally Posted by Unkitoo View Post
    UART?...i dont have pinout or know actual process to clear crash?
