Page 1 of 33 12345611 ... LastLast
Results 1 to 15 of 494
    ReverseFlash's Avatar
    Jan 2017
    North America
    Default Everything iProg related
    We need to share our collective experience on this tool, what works good and what doesn't. Lets be real here...the Chinese sellers don't know shit.
    If I helped you, please consider to rep + thanks me.
  2. The Following 3 Users Say Thank You to ReverseFlash For This Useful Post:
    Aash00 (9th March, 2020), fuzz1 (3rd March, 2020), Gebalana ARJ (15th January, 2024)
  3. #2
    fuzz1's Avatar
    Jul 2019
    There are clone and clone version of iprog. Some clones were reported to work just as good as the original or even better. Some others are just not worth. Mine has two pcb that has been filled with epoxy. You can't get access to any parts or try to repair it. Can't even try to make it work or repair if ever there is something wrong with it.
    Some clones are sold saying never power it up with the DC supply and not to connect it via obd2 port else it will burn. Others have reported that there clone can or powered by dc source other than usb and can be connected to obd2 ports without problems.
    Maybe people should tell us how much they paid for the good clones.
    The clones are better cause you have newer software versions which are not available for the original version
    Mar 2020
    I just got my clone the other day. They claim it's the V80 version.
    I already went ahead and plugged in a 12v external power supply and it didn't blow up. I haven't cracked it open to take a look at which board color I have. What I can report is that my clone cost $ 89.90 before tax/shipping.
    Jan 2017
    North America
    Yeah alot of people saying different things. I finally got this one https://www.aliexpress.com/item/3285...746b4c4dJV8ATN...with all the 7 adapters.
    I might open the obd cable and desolder the power and ground cable on the end going to the iProg, so when I plug it in to do modules by obd, it should be safe.
    Please don/'t power up IPROG by additional 12V Power.
    Do not use OBD2 to connect to the car12V and 24V will not work (if you try it, it will give a burnt smell)
    Must be linked to a computer
    OBD2 line can only be connected to HONDA car
    Other vehicle connections will burn Iprog equipment
    Also my seller has some dumb instructions, would this not brick my iProg.
    Main steps to install V80 iProg Pro:
    Step 1: Create a new folder in any convenient place on the disk. For example [iProgProSoftware]
    Step 2: Unpack the archive into the created folder
    Step 3: Run the program
    Step 4: Select the menu item Help -> Check for Updates. Follow instructions
    Step 5: Copy into your Scrips and Calculators folders your scripts and calculators, respectively
  6. The Following 2 Users Say Thank You to ReverseFlash For This Useful Post:
    orx (8th October, 2020), rtbdiagnostic (15th September, 2020)
  7. #5
    Sep 2019
    saludos ...e comprado varios clones ...mas de la mitad exelentes e podido modificar las calculadoras y anda super bien ...pero ortos que compre verdaderamente no cumple con lo que ofrecen para el costo vale ya que en materia de dash y fujitsu para mi concepto trabaja exelente solo hay que tener ciertos tips con todo gusto aportare mucho sobre el tema clones IPROG+
  8. #6
    Jan 2017
    North America
    Just connected mine to obd2. It didn't burn, and still works. I think if you have the blue board with epoxy, you should be fine.
  9. The Following 3 Users Say Thank You to ReverseFlash For This Useful Post:
    ASCM (1st January, 2021), Littey (11th January, 2021), rtbdiagnostic (19th December, 2020)
  10. #7
    agstur's Avatar
    Aug 2012
    Plovdiv
    I have Iprog clone and i am really satisfied from it.
    90% of dashboard and airbag calculations are good.
    Today i was made Mazda Airbag unit trough OBD.
    It was Infineon XC2361-56F.
    GJR9-57K30B
    Read
    Clear Crash
    Clear errors
    Write
    All trough OBD.
    To Push Buttons,Thanks and Reputation is always best way to thanks!
  11. The Following 8 Users Say Thank You to agstur For This Useful Post:
    ASCM (1st January, 2021), cordero (9th April, 2021), gomarota (26th April, 2020), herath (3rd June, 2021), laurentiudania (29th April, 2021), Littey (11th January, 2021), mastaflex (25th October, 2020), Pzolee (4th October, 2023)
  12. #8
    Jan 2017
    North America
    Quote Originally Posted by agstur View Post
    GJR9-57K30B
    Read
    Clear Crash
    Clear errors
    Write
    All trough OBD.
    Did you ever test Hyundai mobis eprom modules?
  13. The Following User Says Thank You to ReverseFlash For This Useful Post:
  14. #9
    agstur's Avatar
    Aug 2012
    Plovdiv
    No,i didn't!
  15. #10
    fuzz1's Avatar
    Jul 2019
    I ran the following to test my eeprom adpater on iprog and got the following. Can anyone have a look to tell me if it good or if there is something wrong with the adapter?
    Тест установки питания ...
    Установка: 2.6 В, Реально: 2.6 В. (0.0) OK 10B = 9.8 OK
    Установка: 2.8 В, Реально: 2.7 В. (0.1) OK 10B = 9.6 OK
    Установка: 2.9 В, Реально: 2.9 В. (0.0) OK 10B = 9.5 OK
    Установка: 3.1 В, Реально: 3.0 В. (0.1) OK 10B = 9.4 OK
    Установка: 3.4 В, Реально: 3.4 В. (0.1) OK 10B = 9.0 OK
    Установка: 3.8 В, Реально: 3.7 В. (0.1) OK 10B = 9.0 OK
    Установка: 4.3 В, Реально: 4.1 В. (0.2) Ошибка 10B = 8.6 OK
    Установка: 5.0 В, Реально: 4.7 В. (0.3) Ошибка 10B = 8.1 OK
    !!! Ошибки установки питания.
    Тест шины данных...
    VCC = 5.0 В: Ошибки: нет
    VCC = 4.3 В: Ошибки: нет
    VCC = 3.8 В: Ошибки: нет
    VCC = 3.4 В: Ошибки: нет
    VCC = 3.1 В: Ошибки: нет
    VCC = 2.9 В: Ошибки: нет
    VCC = 2.8 В: Ошибки: нет
    VCC = 2.6 В: Ошибки: нет
    >>>>>>>> Тест шины данных завершен...
    Тест коммутации GND ...
    >>>>>>> Тест коммутации GND завершен
    Тест коммутации VCC ...
    VCC = 5.0 В:
    1-8: vcc = 951 OK
    8-1: vcc = 982 OK
    2-7: vcc = 982 OK
    7-2: vcc = 982 OK
    3-6: vcc = 982 OK
    6-3: vcc = 982 OK
    4-5: vcc = 982 OK
    5-4: vcc = 982 OK
    VCC = 4.3 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 988 OK
    3-6: vcc = 988 OK
    6-3: vcc = 988 OK
    4-5: vcc = 988 OK
    5-4: vcc = 988 OK
    VCC = 3.8 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 988 OK
    3-6: vcc = 988 OK
    6-3: vcc = 988 OK
    4-5: vcc = 982 OK
    5-4: vcc = 982 OK
    VCC = 3.4 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 982 OK
    3-6: vcc = 982 OK
    6-3: vcc = 982 OK
    4-5: vcc = 982 OK
    5-4: vcc = 982 OK
    VCC = 3.1 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 988 OK
    3-6: vcc = 982 OK
    6-3: vcc = 982 OK
    4-5: vcc = 982 OK
    5-4: vcc = 982 OK
    VCC = 2.9 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 982 OK
    3-6: vcc = 988 OK
    6-3: vcc = 982 OK
    4-5: vcc = 988 OK
    5-4: vcc = 988 OK
    VCC = 2.8 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 982 OK
    3-6: vcc = 982 OK
    6-3: vcc = 988 OK
    4-5: vcc = 988 OK
    5-4: vcc = 988 OK
    VCC = 2.6 В:
    1-8: vcc = 988 OK
    8-1: vcc = 988 OK
    2-7: vcc = 988 OK
    7-2: vcc = 982 OK
    3-6: vcc = 988 OK
    6-3: vcc = 988 OK
    4-5: vcc = 988 OK
    5-4: vcc = 988 OK
    >>>>>>> Тест коммутации VCC завершен
  16. #11
    Jan 2017
    North America
    I see all oks, and I tried google translate, but couldn't translate the other parts.
  17. #12
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by ReverseFlash View Post
    Are you referring to the results i posted from the iprog?
    I have unfortunately not been able to read any eeprom yet using the iprog. Would it be possible for you to help me with one?
    I would like to thank you again for taking the time to reply.
  18. #13
    Jan 2017
    North America
    Yeah I've managed to read eeproms with this tool, but I wouldn't recommend it. Use the Eeprom adapter, pin #1 is where the lever is.
  19. The Following 2 Users Say Thank You to ReverseFlash For This Useful Post:
    al70 (10th January, 2021), Col19 (6th February, 2021)
  20. #14
    Jan 2017
    North America
    Anyone know why almost all scripts for airbag by obd work except for the KIA - HYUNDAI MOBIS CAN v1.05 script?
  21. #15
    Mar 2020
    Did you tick the 3-11 pin check box? Also to my previous comment. I opened mine also. I didn't see any eproxy or don't recall. Is it on the whole board or a certain IC?
