hi here you have how to connect to clio4 airbag ecu with spc560 processor. If you wont you can ad this script to renault spc folder.
If I helped you, please consider to rep + thanks me
s928s24u (6th March, 2024)
Hello to all.
Today my IPROG ( china original ) died. USB device not recognized. Flashed it with 1.30.s.n0001 bin file. Now it gets recognized by PC and I can use it 2-3 times and then again no usb recognition. Does some one have other file for 91SAM7S256, no other idea what to do? Power board was reworked long time ago and it was working good till today.
IF I HELPED YOU PRESS THE " T " BUTTON
Good afternoon Help is needed.There was no external power supply.
I made a power board. But I have a mistake I can not understand. Where to look for the problem.
Start test
--- Тест VCC = 3V ---
ADC0 (контакт 41) = 3.1 V. OK
--- Тест VCC = 5V ---
ADC0 (контакт 41) = 5.0 V. OK
--- Тест 10/12V ---
Uвых = 10V
ADC2 (контакт 43) = 9.7 V. OK
ADC3 (контакт 44) = 0.0 V. Error
Uвых = 12V
ADC2 (контакт 43) = 11.6 V. OK
--- External power test--
Выключено: 0.0 V. OK
Включено: 5.0 V. OK
--- Тест выводов ---
PORTD.1 (вывод 6): OK.
PORTB.5 (вывод 3): OK
Тест завершен. Ошибок: 2
Removed the 100 Ohm resistor from the plug
Start test
--- Тест 10/12V ---
Uвых = 10V
ADC3 (контакт 44) = 9.1 V. Error
Uвых = 12V
ADC3 (контакт 44) = 10.8 V. Error
--- External power test ---
Включено: 5.0 V. OK
PORTE.0 (вывод 7): OK.
What could be the problem?
