Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 50
  1. #31
    Jun 2023
    United kingdom
    I'm a new member and i would like to know how can i get this program? I need to code abs on a skoda vrs 4x4 2.0 Tfsi swapped abs to 1K0907379CB, is 20 byte, vin TMBEF21Z1A2111482
    Please advise.
    Thank you
  2. #32
    Oct 2019
    Can you please help me with a long code for polo 6R 2013
  3. #33
    Oct 2018
    HI
    I'm looking for a long code for golf+ MK5
    Here PR code a2dfd214cb64b708de9fd7cf76dc823e.jpg and scan
    Tuesday,07,November,2023,15:01:43:16365
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
    Data version: 20230421 DS346.2
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ9W803058 License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 69 72 76
    VIN: WVWZZZ1KZ9W803058 Mileage: 161990km-100655miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: Not registered 0001
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
    Part No SW: 03C 906 027 BS HW: 03C 906 027 F
    Component: MED17.5.5 G 1676
    Revision: L1H05--- Serial number: VWX7Z0H43NL8W8
    Coding: 0000072
    Shop #: WSC 02508 002 1048576
    VCID: 73B3DFD177B6D642029-8026
    VINID: 9E69EAAAA05BA899C800300520E104EFFE
    3 Faults Found:
    001384 - Cruise Control Switch (E45)
    P0568 - 000 - Implausible Signal
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 161731 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:30:37
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 26.0°C
    Temperature: 25.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 11.938 V
    005784 - Please Check DTC Memory of Steering Wheel Electronics
    P1698 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 161731 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:30:37
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 26.0°C
    Temperature: 25.0°C
    Voltage: 11.938 V
    006481 - Radiator Fan 2 (V177)
    P1951 - 000 - Movement Restricted / Jammed - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 161753 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:23:30
    Freeze Frame:
    RPM: 766 /min
    Load: 22.0 %
    Speed: 4.0 km/h
    Temperature: 87.0°C
    Temperature: 48.0°C
    Voltage: 13.462 V
    Readiness: 0000 0000
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 09550 758 180955
    VCID: 74B1DCCD7EB8D17A1B3-8020
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 4608
    Count: 195
    Count: 43008
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
    Component: ClimatronicPQ35 130 1213
    Revision: 00130023 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 698FBDB9257A1C92B85-803C
    1 Fault Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    000 - - - Intermittent
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 01000005739961
    Coding: E78F8F2700041800470A00000F000000000B5D035C00010100 0000000000
    Shop #: WSC 01287 785 00200
    VCID: 33331FD137369642C29-8066
    Subsystem 1 - Part No: 5M0 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 080508 021 0501
    Coding: 00038805
    Shop #: WSC 01287
    Subsystem 2 - Part No: 1K0 955 559 AG Labels: 1K0-955-559-AG.CLB
    Component: RLS 120508 055 0402
    Coding: 04403387
    Shop #: WSC 01287
    No fault code found.
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1D AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD20U6TU
    Coding: 0012612
    Shop #: WSC 01373 785 00200
    VCID: 3D2739E90172503224D-8068
    Subsystem 1 - Serial number: 6332MSME27021734/
    Subsystem 2 - Serial number: 6342MSME332468637
    Subsystem 3 - Serial number: 6351HSME16261763%
    Subsystem 4 - Serial number: 6361HSME163D64056
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
    Component: J0527 051 0101
    Coding: 0002022
    Shop #: WSC 01392 785 00200
    VCID: 015F85193D0AF4D2005-8054
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    1 Fault Found:
    00895 - Cruise Control Switch (E45)
    014 - Defective
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 874 A HW: 1K0 920 874 A
    Component: KOMBIINSTRUMENT VDD 2416
    Revision: V0002000 Serial number: VWX7Z0H43NL8W8
    Coding: 0007103
    Shop #: WSC 00011 888 06946
    VCID: 2B0307B1EF06CE828A9-807E
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533 Gateway H07 0062
    Revision: H07 01 Serial number: 210508F1000742
    Coding: E9817F0E0002029002
    VCID: 353721C939428872ECD-8060
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 104
    Reset counter: 255
    Mileage: 161731 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:30:50
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 2416
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
    Component: Tuer-SG 006 1213
    Coding: 0000180
    VCID: 392F2DF9155A6C12085-806C
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.070 H08 1901
    Shop #: WSC 00000 028 00001
    2 Faults Found:
    02546 - Steering Limit Stop
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Mileage: 161980 km
    Temperature: 15.0°C
    Voltage: 12.10 V
    Voltage: 11.90 V
    00778 - Steering Angle Sensor (G85)
    000 - -
    Freeze Frame:
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 989002005103087F2D04840D6008CF03E0FC00
    VCID: 03538F112716E6C2129-8056
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
    Coding: 0000436
    VCID: 3A2D32F5105C670A01F-806E
    Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
    Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
    Component: AFS-Steuergeraet 0001
    Revision: H02 Serial number:
    Coding: 1196162
    VCID: 323D1AD5C82C9F4AC9F-8066
    Subsystem 1 - Part No: 4F0 941 329 C Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0010
    Coding: 00000018
    Subsystem 2 - Part No: 4F0 941 329 C Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0010
    Coding: 00000018
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: Radio RCD510 036 0126
    Revision: 00000001 Serial number: VWZ1Z3H3239037
    Coding: 0500040004
    Shop #: WSC 01316 785 00200
    VCID: 6597B189C56238F29CD-8030
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1303
    Coding: 0000144
    Shop #: WSC 01392 785 1012552
    VCID: 382928FD2E50751AF7B-806C
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Towbar module H09 0100
    Revision: 3A001001 Serial number: ÀÁ006789,.+00(
    Coding: 0100000100000000
    VCID: 303910DDCA20AD5ABFB-8064
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    2 Faults Found:
    01554 - Motors for Central Locking; Rear Doors; Lock
    012 - Electrical Fault in Circuit - Intermittent
    00931 - Locking Module for Central Locking; Rear Right (F223)
    008 - Implausible Signal - Intermittent
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1K0 919 283 A
    Component: 24 Einparkhilfe 0101
    VCID: 2D0709A9D112C0B294D-8078
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
    Thx
  4. #34
    Aug 2022
    PLEASE HELP FOR LONGCODE
    MK60CE1 1K0907379AD LHD 1.9TDI
    WAUZZZ8P39B021166
  5. #35
    Junior Member beloforte's Avatar
    como obter total?
  6. #36
    Bulgaria, Sofia
    Default Audi A3 8P ESP Lost Long Coding
    Good afternoon, need help with
    Audi A3 8P 2009 , ESP
    1K0 907 379 AD MK60EC1
    lost coding after washing the interior of the interior, the dashboard failed for a few days until we dried the moisture in the passenger compartment.
    1.9 TDI , Left-Hand Drive ( LHD )
    Brake diameter Front : 280 mm , Rear : 253 mm
    NO TPMS button under radio , but Tire Pressure Monitoring No Signal/Communication in CAN Gateway .
    Attach VCDS Log and PR Lable.
    ABS/ESP calculator is not me help.
    Solved, the calculation of 17 and 18 bytes turned out to be a problem
  7. #37
    Jan 2024
    Does anyone know how to get all the VW Spec. and Product Codes required to code ABS module without the sticker. My sticker seems to have been removed by previous owner.
    Thanks in advance.
    Pavlo
  8. #38
    Bulgaria, Sofia
    Quote Originally Posted by PavloOz View Post
    Thanks in advance.
    Pavlo
    Hi, you can try this.
  9. #39
    Sep 2020
    Romania
    Thanks in advance.
    Pavlo
    Give me the VIN nr and i will give you the PR code lost list for your car
  10. #40
    Apr 2023
    Pass please¿¿???
  11. #41
    May 2016
    Hola, gracias.
  12. #42
    May 2016
    Quote Originally Posted by Tefocm View Post
    Hola a todos, actualmente estoy trabajando en un software para realizar cálculos de codificación más precisos. Aún queda mucho trabajo por hacer. Tengan la seguridad de que lo publicaré primero en DK.
    No duden en decirme lo que piensan.
    Any guy is posible pu my long coding?
    Vw golf 2.0tdi 110hp 2009 LHD normal
    VIN: WVWZZZ1KZAP029644 License Plate:
    Mileage: 265850km-165191mi Repair Order:
    Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Shop #: WSC 00028 028 00001
    VCID: 7EA5FEE540F48B2A2D7-802A
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 189
    Time Indication: 0
    Date: 2019.05.23.
    Time: 07:12:07
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 4608
    Count: 195
    Count: 42752
    Count: 1024
    Count: 0
    Count: 0
  13. #43
    Jan 2025
    Default ABS coding
    Quote Originally Posted by srt8 View Post
    hi, here is the vag log for abs coding, long coding.
    I have a quick question: could this tool (or resources recommended here) help me with coding a new ABS module? I'm working on a project that involves [breve descripción del contexto si quieres: e.g., replacing/upgrading an ABS system], and I'd really appreciate any guidance, advice, or tips.
  14. #44
    May 2019
    Good morning
    I was wondering if anyone can help me, i took the instrument cluster out of my car recently and its reset my abs code to 00000 i have no record of the previous code and now my car is stuck with sirens and weird flashing on the dashboard.
    VIN: VSSZZZ1PZ9R008357 License Plate: ########
    Chassis Type: 1P (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
    01-Engine -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKC.clb
    Part No SW: 03G 906 021 SC HW: 03G 906 021 AN
    Component: R4 1,9L EDC G000SG 1438
    Revision: --H08--- Serial number: SEX7Z0H431K086
    Coding: 0050071
    Shop #: WSC 06402 785 00200
    VCID: 72BDCD7BC8A9974A59F-8026
    VINID: 9A38EAAAA060A898800080C51C1FC6A305
    Readiness: 0 0 0 0 1
    Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Shop #: WSC 34755 001 1048576
    VCID: 76B5F16BA8C18B6A757-8022
  15. #45
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    https://www.digital-kaos.co.uk/forum...BS-Long-Coding
    I can help you, but you need to pay by providing me with scans or cash.
    I have sleepless nights to develop a fully functional software and the least you can do is give me the resources to make my software better.
    Buy every pirate China has to offer for cheap...and WIN!
    Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
