You need to install the support for Nexiq. It is not default for IDSS.
Hi all,
i have problems with G-IDSS (V2.5.0.0) + Nexiq USB Link1 (124032 China Clone, Driver Software V9.5.0.1).
I get in contact with the car and can retrieve e.g. the module information. But I can't retrieve the error list DTC for example. Something goes wrong and the two yellow flash icons in the G-IDSS software disappear. I must restart G-IDSS.
I think my selfmade patch for the registry does not pass. And i can't see the "Select Device" Button in the menu. Query of the VIN does not work, too.
Can someone send me their registry entry ("passthrusupport" and "passthrusupport.04.04") or a picture of it?
I would be very grateful for any hint!
Thanks and best regards
Ben
Technical Support: Cummins + CAT + Perkins + Volvo Truck + Volvo Penta + Detroil Diesel + Isuzu + Scania, etc...
Support Remote Installation and diagnostics
stargate2010 (3rd March, 2020)
I have already installed the Nexiq driver (version V9.5.0.1). What do you mean with "support for Nexiq"? Do I need additional software besides the driver?
By the way: Iam using G-IDSS (international global Version) not IDSS.
I once added two log files of G-IDSS:
The first one shows the query of the engine ECU module. This is successful, no problems.
UTC TIME |EVNT|MESSAGE
2020-03-02T21:51:25.697|OTHR|Web Update=2.5.0.0
2020-03-02T21:51:25.697|OTHR|Package Code=idss-de1
2020-03-02T21:51:25.697|OTHR|G-IDSS Version=3.7.0320.3652
2020-03-02T21:51:25.697|OTHR|ProcessorCount=2
2020-03-02T21:51:25.697|OTHR|OSVersion=Microsoft Windows NT 6.1.7601 Service Pack 1 (5.1=XP,5.2=XP64,6.0=Vista,6.1=Win7,6.2=Win8,6.3=W in8.1,10.0=Win10)
2020-03-02T21:51:25.697|OTHR|CLR Version=2.0.50727.5420
2020-03-02T21:51:25.697|OTHR|High Resolution Clock Available=True
2020-03-02T21:51:25.697|OTHR|PC Time Measurement Accuracy=+/-0,0014371717ms
2020-03-02T21:51:25.697|OTHR|Vehicle ID=9832
2020-03-02T21:51:25.697|OTHR|Module ID=345
2020-03-02T21:51:25.697|OTHR|Module Name=4JK1
2020-03-02T21:51:25.697|OTHR|Database Name=RT56_4JK1_Engine_N46STS-0001_Engine_2ndstage.pts
2020-03-02T21:51:25.697|OTHR|Specification=N46STS0001
2020-03-02T21:51:25.729|CONN|**** Connect Start ****
2020-03-02T21:51:25.729|CONN|Protocol Name=ISO15765(#6)
2020-03-02T21:51:25.729|CONN|DATA_RATE=500000
2020-03-02T21:51:25.729|CONN|LOOPBACK=0
2020-03-02T21:51:25.729|CONN|BIT_SAMPLE_POINT=80
2020-03-02T21:51:25.729|CONN|SYNC_JUMP_WIDTH=15
2020-03-02T21:51:25.729|CONN|ISO15765_BS=0
2020-03-02T21:51:25.729|CONN|ISO15765_STMIN=0
2020-03-02T21:51:25.729|CONN|DLLName:=C:\Windows\system32\ NXULUJ32.DLL
2020-03-02T21:51:25.729|CONN|DLLVersion:=9.5.0.0
2020-03-02T21:51:25.729|CONN|APIVersion:=04.04
2020-03-02T21:51:25.729|CONN|Firmware:=2.500134
2020-03-02T21:51:25.729|CONN|Calling Connect
2020-03-02T21:51:25.733|CONN|ChannelID=258
2020-03-02T21:51:25.741|CONN|SetConfig: Complete
2020-03-02T21:51:25.742|OTHR|Begin StartMessageFilters
2020-03-02T21:51:25.752|OTHR|PATTERN 00 00 07 E8
2020-03-02T21:51:25.752|OTHR|MASK FF FF FF FF
2020-03-02T21:51:25.752|OTHR|FLOW 00 00 07 E0
2020-03-02T21:51:25.752|OTHR|FlowControl Filter Started Id=529
2020-03-02T21:51:25.761|OTHR|PATTERN 00 00 05 E8
2020-03-02T21:51:25.761|OTHR|MASK FF FF FF FF
2020-03-02T21:51:25.761|OTHR|FLOW 00 00 07 E0
2020-03-02T21:51:25.761|OTHR|FlowControl Filter Started Id=530
2020-03-02T21:51:25.761|OTHR|Done StartMessageFilters
2020-03-02T21:51:25.761|CONN|Done Connect Result=True
2020-03-02T21:51:25.761|CONN|**** Connect Done ****
2020-03-02T21:51:25.798| TX |00 00 07 E0 1A 90
2020-03-02T21:51:25.834| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:25.834|OTHR|Wait extended 1000ms.
2020-03-02T21:51:25.884| RX |00 00 07 E8 5A 90 4D 50 41 54 46 53 38 36 4A 43 54 31 30 32 34 33 39
2020-03-02T21:51:25.885| TX |00 00 07 E0 1A 92
2020-03-02T21:51:25.919| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:25.919|OTHR|Wait extended 4800ms.
2020-03-02T21:51:25.959| RX |00 00 07 E8 5A 92 54 54 49 20 20 30 31 30 30
2020-03-02T21:51:25.960| TX |00 00 07 E0 1A 95
2020-03-02T21:51:25.994| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:25.994|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.019| RX |00 00 07 E8 5A 95 00 02
2020-03-02T21:51:26.020| TX |00 00 07 E0 1A 98
2020-03-02T21:51:26.054| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.054|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.094| RX |00 00 07 E8 5A 98 42 30 31 34 2D 38 30 32 32 37
2020-03-02T21:51:26.095| TX |00 00 07 E0 1A 99
2020-03-02T21:51:26.130| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.130|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.154| RX |00 00 07 E8 5A 99 20 15 03 17
2020-03-02T21:51:26.155| TX |00 00 07 E0 1A 9A
2020-03-02T21:51:26.191| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.191|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.214| RX |00 00 07 E8 5A 9A 8C 1C
2020-03-02T21:51:26.215| TX |00 00 07 E0 1A A0
2020-03-02T21:51:26.249| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.249|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.274| RX |00 00 07 E8 5A A0 00
2020-03-02T21:51:26.275| TX |00 00 07 E0 1A C2
2020-03-02T21:51:26.309| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.309|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.349| RX |00 00 07 E8 5A C2 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
2020-03-02T21:51:26.350| TX |00 00 07 E0 1A CB
2020-03-02T21:51:26.384| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.384|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.409| RX |00 00 07 E8 5A CB 05 DB 2F A0
2020-03-02T21:51:26.410| TX |00 00 07 E0 1A CC
2020-03-02T21:51:26.444| RX |00 00 07 E8 7F 1A 78
2020-03-02T21:51:26.444|OTHR|Wait extended 1000ms.
2020-03-02T21:51:26.469| RX |00 00 07 E8 5A CC 00 F4 4D 54
2020-03-02T21:51:43.673|DISC|Disconnect Start
2020-03-02T21:51:43.793|DISC|Disconnect Channel ID=258
The second log file shows the query of the DTC of the engine ECU. Something seems to go wrong. I also cannot see any receive (RX) entrys:
2020-03-02T21:33:04.748|OTHR|Web Update=2.5.0.0
2020-03-02T21:33:04.748|OTHR|Package Code=idss-de1
2020-03-02T21:33:04.748|OTHR|G-IDSS Version=3.7.0320.3652
2020-03-02T21:33:04.748|OTHR|ProcessorCount=2
2020-03-02T21:33:04.748|OTHR|OSVersion=Microsoft Windows NT 6.1.7601 Service Pack 1 (5.1=XP,5.2=XP64,6.0=Vista,6.1=Win7,6.2=Win8,6.3=W in8.1,10.0=Win10)
2020-03-02T21:33:04.748|OTHR|CLR Version=2.0.50727.5420
2020-03-02T21:33:04.748|OTHR|High Resolution Clock Available=True
2020-03-02T21:33:04.748|OTHR|PC Time Measurement Accuracy=+/-0,0014884993ms
2020-03-02T21:33:04.748|OTHR|Vehicle ID=9832
2020-03-02T21:33:04.748|OTHR|Module ID=345
2020-03-02T21:33:04.748|OTHR|Module Name=4JK1
2020-03-02T21:33:04.748|OTHR|Specification=N46STS0001
2020-03-02T21:33:04.748|OTHR|Database Name=RT56_4JK1_Engine_N46STS-0001_Engine_2ndstage.pts
2020-03-02T21:33:04.754|CONN|**** Connect Start ****
2020-03-02T21:33:04.754|CONN|Protocol Name=ISO15765(#6)
2020-03-02T21:33:04.754|CONN|DATA_RATE=500000
2020-03-02T21:33:04.754|CONN|LOOPBACK=0
2020-03-02T21:33:04.754|CONN|BIT_SAMPLE_POINT=80
2020-03-02T21:33:04.754|CONN|SYNC_JUMP_WIDTH=15
2020-03-02T21:33:04.754|CONN|ISO15765_BS=0
2020-03-02T21:33:04.754|CONN|ISO15765_STMIN=0
2020-03-02T21:33:04.754|CONN|DLLName:=C:\Windows\system32\ NXULUJ32.DLL
2020-03-02T21:33:04.754|CONN|DLLVersion:=9.5.0.0
2020-03-02T21:33:04.754|CONN|APIVersion:=04.04
2020-03-02T21:33:04.754|CONN|Firmware:=2.500134
2020-03-02T21:33:04.754|CONN|Calling Connect
2020-03-02T21:33:04.759|CONN|ChannelID=257
2020-03-02T21:33:04.765|CONN|SetConfig: Complete
2020-03-02T21:33:04.766|OTHR|Begin StartMessageFilters
2020-03-02T21:33:04.776|OTHR|PATTERN 00 00 07 E8
2020-03-02T21:33:04.776|OTHR|MASK FF FF FF FF
2020-03-02T21:33:04.776|OTHR|FLOW 00 00 07 E0
2020-03-02T21:33:04.776|OTHR|FlowControl Filter Started Id=259
2020-03-02T21:33:04.786|OTHR|PATTERN 00 00 05 E8
2020-03-02T21:33:04.786|OTHR|MASK FF FF FF FF
2020-03-02T21:33:04.786|OTHR|FLOW 00 00 07 E0
2020-03-02T21:33:04.786|OTHR|FlowControl Filter Started Id=260
2020-03-02T21:33:04.786|OTHR|Done StartMessageFilters
2020-03-02T21:33:04.786|CONN|Done Connect Result=True
2020-03-02T21:33:04.786|CONN|**** Connect Done ****
2020-03-02T21:33:04.792|OTHR|Log Continued from NodeListDisplayMaintainComm RT56 4JK1_Act70 2020-03-02T21-33-03-75
2020-03-02T21:33:04.930| TX |00 00 07 E0 A9 81 12
2020-03-02T21:33:07.051|OTHR|The wait for a response timed out after 2000ms.
2020-03-02T21:33:07.056| TX |00 00 07 E0 A9 81 12
2020-03-02T21:33:09.139|OTHR|The wait for a response timed out after 2000ms.
2020-03-02T21:33:09.145| TX |00 00 07 E0 A9 81 12
2020-03-02T21:33:11.241|OTHR|The wait for a response timed out after 2000ms.
2020-03-02T21:33:11.360|OTHR|Start Diagnose Vehicle Connection
2020-03-02T21:33:11.363|DISC|Disconnect Start
2020-03-02T21:33:11.483|DISC|Disconnect Channel ID=257
Is anyone of you an expert and can see the problem?
Thanx a lot!!!
Ben
sr for rp adapters clones you need the passtrhu drivers g-idss it must have that idss work ok without it
if yo fix you problem let me know i do have the 2020 g-idss update and the activator for thatg-idss.png
cbp (29th August, 2022), stargate2010 (16th July, 2020)
If you installed G-IDSS and have ecm to connect, send Teamviewer to me. I will fix it by teamviewer for you. Free!!!!
Dear yahir,
can you send me the 2020 G-IDSS Update and activator? Thank you very much!
Ben
Send teamviewer. I could fix it for you
Hello Yahir...could you please help me with the J2534 fix ?
cheers
My wife said that i have no hair, have big ears ..but a great smile.
