Results 1 to 1 of 1
Threaded View
    Jan 2019
    Somewhere between Continents
    Default 2015 Ford F150 ABS Module PinOut
    hello there.
    Is there anyone that could help me out with the ABS Module pinout to see if i can test communications on the bench?
    The ABS Module throughs a communication problem and i can do the "Pump Test" on the car and i want to see if i can test it on the bench...
    Or if anyone has the pinout for this truck i would appreciate...
    These are the DTCs i´m getting:
    ===PSCM DTC U0121:00-08===
    Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module A
    ===IPC DTC U0121:00-08===
    ===ABS DTC U0151-20===
    Code: U0151 - Lost Communication With RCM
    ===ABS DTC U0131-20===
    Code: U0131 - Lost Communication With Power Steering Control Module
    ===ABS DTC C1300-F0===
    Code: C1300 - ABS Pump Motor Circuit Failure
    I got the module from the truck, open it to see if i could find any issues inside, but it seems all is ok.
    Still need to measure some sort of transistors but i need to try and find datasheet for these.
    If anyone could help also on this it would be great.
    Anyone that had this on the past that could help i would appreciate.
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
