Results 1 to 9 of 9
    Sep 2012
    Default Ford incode help
    Hi all I'm in need of an incode for ford mondeo 2011
    i am struggling getting an incode if someone on here could help me out I would really apreiciated it
    vin WF0EXXGBBEBK55563
    outcode 1044 048C75 F6D048
    i will pay for code if need be it isn't a problem if someone can supply incode or has any suggestions where I might get the code from I do not have an etis account
    I'm using ids
    Thankyou in advance I really apreiciated your time /help
    Nov 2015
    Tm100 software have ford incode outcode calculator
    Trimis de pe al meu SM-G950F folosind Tapatalk
    If i help press the magic button
    Sep 2012
    Thankyou I don't have that at moment but will buy one ASAP
    Nov 2015
    Quote Originally Posted by shifty67 View Post
    p
    incode
    DA7C
    Nov 2015
    tm100 software , you can calculate !
  6. The Following User Says Thank You to pinovlad88 For This Useful Post:
    shifty67 (21st March, 2020)
    Sep 2012
    thankyou pinovalad88 and others for your help and my appologies for delay in saying thankyou ive had a bereavement in my family
    Quote Originally Posted by pinovlad88 View Post
    incode
    DA7C
    Oct 2018
    Hi guys, I have a FG Falcon 2010
    Vin: 6FPAAAJGSWAM44778
    Outcode: 0004-1273C5-362D74
    I have Abrites Ford Incode caculator, it give me incode: 0000-54B8
    Now i try to reset the PCM after do the keys with GScan2, I put in the 54B8, but nothing happend, put in 000054B8 it fail
    I try the outcode from this thread owner 1044 048C75 F6D048 , i have incode 74D5-DA7C
    So, i assume abrites give me the right incode but the way i use it is incorrect?
    Can anyone shed some lights on this matter? Thanks
    racin-snake's Avatar
    Jun 2009
    outcode 1044 048C75 F6D048 this is on the new algo system so most calculators wont work . no idea if its been cracked by AVDI or any other ( craptoworks doesn't work )
    MAY need ford FDRS ( ONLINE ). YOU COULD TRY FMPC001 TO CALCULATE SINGLE OUTCODE ... BUT DUAL OUTCODES HAVE NEVER WORKED FOR ME
    single outcode for key but dual for module initialisation
    so OLD algo tools won't generate correct code this is why it wont accept your 1044 - code
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  10. #9
    Oct 2018
    Quote Originally Posted by racin-snake View Post
    Thanks mate for the info, i think AVDI only give me the last 4 digits of the incode, the first 4 digits 0000 is not correct that why it doesnt do the PCM parameter reset.
    My car outcode is 0004-1273C5-362D74 not 1044 048C75 F6D048
    The outcode 1044 048C75 F6D048 is from this thread, i just use it on AVDI to see if it give the right code people give to shifty67
    I dont have FMPC001 to try, never use ford FDRS ( ONLINE ) ^^ but will have a look at that. Are there any other online paid service for this new incode caculation? Thanks
