Tm100 software have ford incode outcode calculator
Trimis de pe al meu SM-G950F folosind Tapatalk
Hi all I'm in need of an incode for ford mondeo 2011
i am struggling getting an incode if someone on here could help me out I would really apreiciated it
vin WF0EXXGBBEBK55563
outcode 1044 048C75 F6D048
i will pay for code if need be it isn't a problem if someone can supply incode or has any suggestions where I might get the code from I do not have an etis account
I'm using ids
Thankyou in advance I really apreiciated your time /help
If i help press the magic button
Thankyou I don't have that at moment but will buy one ASAP
tm100 software , you can calculate !
shifty67 (21st March, 2020)
Hi guys, I have a FG Falcon 2010
Vin: 6FPAAAJGSWAM44778
Outcode: 0004-1273C5-362D74
I have Abrites Ford Incode caculator, it give me incode: 0000-54B8
Now i try to reset the PCM after do the keys with GScan2, I put in the 54B8, but nothing happend, put in 000054B8 it fail
I try the outcode from this thread owner 1044 048C75 F6D048 , i have incode 74D5-DA7C
So, i assume abrites give me the right incode but the way i use it is incorrect?
Can anyone shed some lights on this matter? Thanks
outcode 1044 048C75 F6D048 this is on the new algo system so most calculators wont work . no idea if its been cracked by AVDI or any other ( craptoworks doesn't work )
MAY need ford FDRS ( ONLINE ). YOU COULD TRY FMPC001 TO CALCULATE SINGLE OUTCODE ... BUT DUAL OUTCODES HAVE NEVER WORKED FOR ME
single outcode for key but dual for module initialisation
so OLD algo tools won't generate correct code this is why it wont accept your 1044 - code
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
Thanks mate for the info, i think AVDI only give me the last 4 digits of the incode, the first 4 digits 0000 is not correct that why it doesnt do the PCM parameter reset.
My car outcode is 0004-1273C5-362D74 not 1044 048C75 F6D048
The outcode 1044 048C75 F6D048 is from this thread, i just use it on AVDI to see if it give the right code people give to shifty67
I dont have FMPC001 to try, never use ford FDRS ( ONLINE ) ^^ but will have a look at that. Are there any other online paid service for this new incode caculation? Thanks
