Results 1 to 9 of 9
    Mar 2020
    Default Corsa d passcode
    Hi, corsa 1.2 2007 ,due to flat battery the bcm has lost the passcode i know i can pay vauxhall to get me this but is there any other way to retreaive this , my nephew has opcom but this wont read the code from ecu , is there any other way without paying to much ,,, its my 17 year old daughters car as shes learning to drive , hence dont want to spend to much , any info appreciated,
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    if you do not have a programmer to read the memory, you will rather not do anything yourself
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
    Nov 2015
    With FVDI you can read the pin code via obd
  4. The Following User Says Thank You to ilDandi For This Useful Post:
    Footymad1001 (8th March, 2020)
    Jul 2019
    opcom can read some. carprog can read them
  6. The Following User Says Thank You to CAN Diagnostic For This Useful Post:
    Mar 2020
    Thankyou, something like carprog v10.93 , would this read corsa d ?
  8. #6
    Jul 2019
    yes it would
  9. The Following User Says Thank You to CAN Diagnostic For This Useful Post:
  10. #7
    Dec 2012
    GARAGE
    Read 35080 from dash with any programmer ex. carprog.
    BR
  11. #8
    Mar 2019
    Earth
    Also you can read the mp3 player, usually the come with cd30mp3 which uses 24c32 eeprom
    Trimis de pe al meu STK-LX1 folosind Tapatalk
  12. #9
    Mar 2020
    You can buy the code from Vauxhall normally about £25.
    Ways for get the code for free.
    look for the car pass.
    4 number code.
    It is normally the same code as the radio but not always. That you can get a radio code for under £5
    If you can’t see the hand book look under passenger seat draw.
    If no good look at the number plate , Hand book , window sticker for the supplying car dealership
    Give them a call as the normally keep in on file.
    You might need some one with Tech 2 to rest BCM for you when you get the code.
    Note if it lost the codes from BCM it normal due to jump starting the car incorrect way around.
