Results 1 to 8 of 8
    Sep 2018
    Default Xentry passthru Ignition control ON/OFF
    Hi! This program activate ignition ON/OFF for DAS. This for only passthru-adapters VAS5054, Mongoose...
    Unzip to the ProgramData / Mercedes-Benz / csd / writefil / sim folder next to the global.sim file. Then you can make a shortcut to the desktop and the lower task bar - it’s more convenient to switch.
  2. The Following 19 Users Say Thank You to zaharich72 For This Useful Post:
    Adamus113 (19th November, 2023), Alehaaneri (12th December, 2023), ANIS2010 (27th June, 2024), bananowamamba (27th November, 2023), Chen3 (13th April, 2023), Ciupaga (2nd August, 2024), Col19 (14th January, 2021), daviddave (11th August, 2024), feferonka123 (4th September, 2023), Gazaam (27th June, 2021), hrdinaveliky3 (10th June, 2021), JanusCars4251 (30th June, 2023), krystianmarzec9 (4th April, 2023), kysioo (9th December, 2022), LP72 (24th July, 2022), nazarij (20th May, 2023), ruwi (16th June, 2024), urcarpc (19th July, 2024)
  3. #2
    Nov 2020
    Hey do you help me, I have ignition ON/OFF problem
    Jul 2022
    This is what I needed!
    Jul 2022
    hello everyone
  6. #5
    Apr 2023
    pobieram i sprawdzam
  7. #6
    Jun 2023
    Will this work on 03/2023 passthru with Openport 2.0 ? Thank you.
  8. #7
    Aug 2019
    Los Angeles, CA
    having this issue with my Xentry Pass Thru 03.2023 tried everything, run as administrator, uninstalled, reinstalled a fresh copy, nothing works
    any help?
    Thank you!
  9. #8
    May 2024
    Default Hope this helps me out
    Quote Originally Posted by zaharich72 View Post
    Not tested yet....hope it helps me out
