Results 1 to 10 of 10
Hybrid View
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default AFTER CARPROG REFLASH WINDOWS DON'T RECOGNIZE THE DEVICE
    i re flash my carprog, with jlink, at the end of programming i have successfully writing and verifying...
    i had solder the 55 pin cable to ground,
    i put back the eeprom, solder the 55 pin, and connect the usb cable to carprog.....
    now i have unknown device connected..... i repeat the procedure,but i have the same result....
    what i am doing wrong?
    Meat-Head's Avatar
    Start with different USB port
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    doctore (9th March, 2020)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I try that, not working....
    Before re flash always I use that USB and it works great.....
    Aug 2018
    East Pole
    In jlink screen did you saw the arm recognized? Maybe you didn't rewrite it ok. Or the AT ic was soldered wrong. Does the AT getting hot? I put one upside down by mistake and blew away a CP once
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by volorucinski View Post
    As i mention in my first post, jlink prompt success write the processor, but when I connect the carprog to USB I have unknown device connected.....
    I use other flash, not that my carprog had... But is almost the the same...
    Aug 2018
    East Pole
    Quote Originally Posted by Panathaole View Post
    Upto ftdi seems to work, but from ftdi to mcu something does not communicate. Obvious something went wrong on reflashing or the bootloader got f*cked up. P. S. I am always removind the at88 before flashing. and always got a good reflash.
    Aug 2008
    no need to remove at88
    but also this could be firmware problem
    try a different bin
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i try again to reprogram the mcu, but this time i get an error.....
    is this the correct mcu AT91SAM7S256D-AU ?
  10. #9
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I think i have problem with the mcu....
    I use glue to keep the cable for the reset pin, and goes under the chip, I desolder the mcu to clean the legs, and I broke 3-4.....
    I order new mcu, I try to programming when I get it.....
  11. The Following User Says Thank You to Panathaole For This Useful Post:
    Stelaras26 (12th March, 2020)
  12. #10
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    check in forum there is a thread here about carprog reflashing which has inside good carprog dumps working online and with 12.45 version too..
    Also has plenty of jlink pinouts,i have uploaded an easy way to program this one too
    If i Helped you,use thanks and rep button to thank me back
  13. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Panathaole (12th March, 2020)
