Mazda IDS and Tactrix Openport J2534
Results 1 to 11 of 11
    Nov 2010
    90
    Default Mazda IDS and Tactrix Openport J2534
    Hello guys,
    I have a Tactrix Openport interface which works perfectly and fast with Techstream.
    I read on the compatibility list that this interafce is also compatible with:
    - Mazda IDS
    - Ford IDS
    - Honds HDS
    - JLR
    Any one have some info/experience with these OEM software running with Tactrix Openport and how to install?
    Sep 2018
    Austria
    69
    Hello there,ive managed to get it working with forscan,very simple,seems like a nice diagnosis,but you have to pay a few euro to got all working coding adaptations,etc(You can activate a month free full trial)...
    IDS-Couldnt connect
    Now im trying to get it work with odis,it recognises that its connected to the car but doesnt recognise ignition and cannot access any component?
    Did you managed something?
    Nice regards
    Mar 2017
    35
    Quote Originally Posted by Msmax View Post
    Hello guys,
    - Mazda IDS
    - Ford IDS
    - Honds HDS
    - JLR
    hallo freind i read also it work on mercedes cars on xentry
    Nov 2010
    90
    Till now for me it works with:
    - Techstream (very fast)
    - JLR
    - Forscan
    Please add any more to the list only if you have tested it..
    Thanks.
    Mar 2017
    35
    - JLR
    - Forscan
    Thanks.
    friend what version software techstream,and version of jlr sdd you are using on it,do you have a link for seller you buy it from because their is many of it,thank you
    Nov 2010
    90
    Quote Originally Posted by ali lbl View Post
    Hello Ali,
    It works with all versions of Techstream. Just install Techstream, install Tactrix drivers and select the correct interface in Techstream VIM setup.
    Will check later the version of JLR I have installed.
  7. The Following User Says Thank You to Msmax For This Useful Post:
    ali lbl (13th October, 2020)
  8. #7
    Mar 2017
    35
    Hello Ali,
    friend from where you buy it .many type their on aliexpress different names of board and chip.you had it from long timeTactrix Openport 2.0 With ECU FLASH ECU Chip
    full chip gold
    blach chip
  9. #8
    Nov 2010
    90
    full chip gold
    blach chip
    Ali,
    I also order it from AliExpress. Revision E, Full chip etc...
    JLR version 158 is installed on my laptop.
    Regards, Msmax
  10. The Following User Says Thank You to Msmax For This Useful Post:
  11. #9
    Mar 2017
    35
    Ali,
    Regards, Msmax
    hallo friend i watch some tests on youtube it work also on Nissan consult SOFTWARE
    friend on Toyota techstream will it work on all obd2 protocols or only for CAN, thanks
  12. #10
    Nov 2010
    90
    I tried to make it work for Nissan but could not succeed.
    Tactrix Open Port only have K-Line and CAN bus (no VPW and PWM hardware) hardware on board. So except on very OLD model Toyota's you will be able to diagnose all systems on newer cars.
    And yes... it should also work with:
    - Mercedes Xentry
    - BMW ISTA
    But I did not try it...
    For Mercedes I use Part D with version 09.2013 for older cars and SDConnect with 10.2019 for newer models. Just installed Xentry 06.2020, still have to test it.
    For BMW I use the famous K+DCAN with ISTA/Ediabas. Works perfect for diagnose functions.
  13. The Following User Says Thank You to Msmax For This Useful Post:
    ali lbl (24th October, 2020)
  14. #11
    Mar 2017
    35
    - Mercedes Xentry
    - BMW ISTA
    FRIEND WHAT INPA K+DCAN BOARD YOU ARE USE FTDI Chip FT232RL OR FT232RQ ,IAM SEARCH IN A GOOD SELLER ON ALIEXPRESS ,DO YOU RECOMMAND A ONE BRO
    THANKS
    YES I READ A ABOUT TACTRIX IT WILL WORK ALSO ISTA THEIR IS SOME STEPS NEED TO MAKE IT WORK
