Results 1 to 5 of 5
    Question Nissan NT400 35.13 how to clean dpf?
    Trivial thread name.
    Have this little truck with dpf mil ON, the truck is not listed in the latest Launch,
    it is not listed in Actia, it is not listed in old BrainBee.
    The lil truck has a dpf button in the consolle, but the owner manual is missing,
    how can I perform a forced clean to the dpf?
    Thank you.
    ______
    rideon's Avatar
    RO
    Not sure
    First check if oil service is overdue.
    Try to drive it for a while
    If that fails and the engine is warm enough ,try neutral/park brake on/and spam that dpf button,
    Nothing to lose except a couple of hours
    A failure will not appear till a unit has passed final inspection
  3. The Following User Says Thank You to rideon For This Useful Post:
    alessioblaupunkt (12th March, 2020)
    Nope. Ish not working but I'll hit your button.
    ______
  5. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    rideon (12th March, 2020)
  6. #4
    rideon's Avatar
    RO
    Quoted for future reference
    To kick off a manual DPF regeneration you should
    1. Put the vehicle in neutral
    2. Put on the hand brake
    3. Leave the pedals alone!
    4. Press and hold the DPF button for 2 seconds or longer
    This is suppose to be some generic instruction on how to use said button
    French seems to rebadge that nissan and called it "maxity" .Add that in the thread title,might be useful.
    Try searching for some french user manual,
  7. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (26th March, 2020)
  8. #5
    Got a "quick scan" with Launch x431 and these come out:
    P20B9
    P20C1
    both related to heater inside AdBlue tank.
    Fix the heater first then you can do regeneration. Maybe.
    I'll check wiring and eventually remove the AdBlue Tank for heater change.
    NT400 can't find nothing, silly name, Launch call it CABSTAR and the other name is F24.
    ______
