Results 1 to 13 of 13
    Dec 2019
    Germany
    Default Cloning EDC17CP14 - OTP Area calculation?
    Hi@all
    I have a EDC17CP14 with damaged Controller. I have to clone this but because of OTP Area the new one has Immobilizer Active. The clone works, but only with Immo-off. The big Problem is: I can't use the firmware of the new one because it's coding isn't correct (DSG not 6 Gear Transmission).
    Is there someone who can calculate my old Firmware for the new OTP or can someone solve the Coding Problem in Flash?
    Dec 2019
    Germany
    Workaround Solution for now: Flashed the new ECU with Flash from old one and EEPROM from new one. That's keeps the ESP and ABS lamps off, Car has full power, ImmoOff works without Immo Active warning. Only Error that lasts til now is something with Coding. In VCDS coding says 000000 instead of 000172 and shows coding error if we will change as before.
    I hope i can help someone with the same problem.
    Actually i'am looking for the Section in Flash which contents the coding. If i can set this manually, i think its solved.
  3. The Following 2 Users Say Thank You to audigy200 For This Useful Post:
    chli1976 (15th March, 2020), hikeven (11th December, 2022)
    Jun 2009
    AVDI or VVDI user should can clone it
    Oct 2016
    Slovakia
    Try and report please
  6. The Following User Says Thank You to jokir For This Useful Post:
    audigy200 (16th March, 2020)
    Dec 2019
    Germany
    AVDI also can't write the OTP Area, we have AVDI testet with no luck
  8. #6
    Dec 2019
    Germany
    Quote Originally Posted by jokir View Post
    We will try that . Car will be here on Tuesday... I will give feedback.
  9. #7
    Jun 2009
    Quote Originally Posted by audigy200 View Post
    No tool can write OTP area
    But AVDI should have a tool inside for clone the dumps eep and flash
  10. #8
    speedy100's Avatar
    Athens
    Hi@all
    If You are good at soldering and have the right tools You can just swap Processor and EEPROM and it will work first try...
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  11. The Following User Says Thank You to speedy100 For This Useful Post:
  12. #9
    Dec 2019
    Germany
    Quote Originally Posted by chli1976 View Post
    Is this working after Tuning Protection?
  13. #10
    Jun 2013
    EU
    Mate if your knowledge about "OTP area" is what you said here i kindly advice you not to touch any other ecu and move to other play field. Let professionals do that work.
    No offense, just a friendly advice.
    Nice day.
  14. #11
    Dec 2019
    Germany
    Quote Originally Posted by morgano View Post
    Nice day.
    We have decryted the Eeprom Data and could change the Coding. Problem solved. Car is working now without errors and the coding is perfect now. My knowledge about otp area is very well. I know that OTP is fused Area which get burned after first time writing. I know also that it is impossible to rewrite. Because of that i had asked initially what i can do to clone ecu with OTP old and written.
    I'am Developer in a big electronic Concern. I'am very well with tricores not only in Cars.
    Is there someone who can calculate my old Firmware for the new OTP or can someone solve the Coding Problem in Flash? -> That's my initially question. Somyone says that AVDI can do the job, i only asked why because writing OTP is impossible. Please don't change my words.
  15. #12
    Dec 2019
    Germany
    Quote Originally Posted by speedy100 View Post
    Best Regards
    Soldering tricore with Grid Array in EDC17cp14 models is not always working because of heat-sensitivity. We have 10ecu soldered where 2 does not work after. You have to heat up complete Board about 100°...
    For us it's only a emergency solution...
    Thank you and have a good day
  16. #13
    speedy100's Avatar
    Athens
    Yes I know about difficulty here. This is why i mentioned skills and equipment.
    I am glad You solved it in a different way though.
    Best Regards
