Results 1 to 5 of 5
    Mar 2013
    Default Lexia 3 Interface Change Revision Serial
    Hello everyone
    i've searched everywhere but cant seem to find solution
    I have a lexia 3 interface with 921815 C revision serial which I updated from 921815 B wich was working fine for few years
    Recently I reinstalled Diagbox 7.82 and the interface is not recognized by the software anymore
    Diagbox 7.82 says Please connect VCI
    Diagbox 7.02 says Communication with intarface card impossible
    in windows it is recognised correctly and drivers and usb are ok
    The problem is I think now the PSA interface checker shows Revision Serial 962830 C
    so somehow it changed the revision serial number
    so question is how to revert the serial number back to 921815 C
    Mar 2013
    also tried older versions of diagbox and firmware but same result
    Jun 2009
    Hello lucim12
    i´m in the same situation.
    i used vci update and the serial changed to 962830 C - now no vci connetion!!
    could you please help?
    thank you so much
    Jan 2010
    Failingup do you still have the same issue? if so I can guide you.
    Nov 2022
    Hi mate, the same thing happens to me as to the mate in the post, and I'm looking for a solution, my serial number has changed, could you help me? Thanks in advance
