Results 16 to 30 of 42
  1. #16
    Jun 2017
    Quote Originally Posted by Freezzby View Post
    Did you test it ? I changed vin with fvdi on a mini 3k91d and error gone about id .
    Perhaps on 0k50e don't work.
    Yes try whit fvdi .
    Didn't work for me
  2. #17
    Jun 2017
    Yes .
    It's was first think what i did
    Maybe may fvdi is rubbish .
    Replace vin whit fvdi after turning ignition off and then on old vin was back
  3. The Following User Says Thank You to Marens2007 For This Useful Post:
    Freezzby (25th March, 2020)
  4. #18
    Fr
    Hi Marens2007 what version do you search hw 09 sw19 ?
    Why do you want to change the mcu ?
    Your eeprom it's ok ?If yes you need to find the flash to repair the dash.
  5. #19
    Jun 2017
    I bought mini with no dash.
    Replace whit second hand.
    Try change vin whit fvdi no luck.
    Try post eeprom data in forums and ask for help to replace vin.
    No luck didn't ask foe for free.
    So there is my story
  6. #20
    Jun 2017
    Actually get old speedo from old owner.
    There was no light on and when you plug speedo in car battery was empty after 12h .
  7. #21
    May 2018
    Hi Moe1988,
    I finally received my Xprog hardware.
    Should I connect the EXTAL pin it's telling that in some cases we don't connect it to PCB?
  8. #22
    narkeleptk's Avatar
    May 2017
    USA
    You only need xtal if its secured. If unsecured just need VCC, GND, RESET, BKGD.
    Don't know which it is. Usually dash units are unsecured tho.
  9. #23
    May 2018
    thanks for your feedback narkeleptk,
    I guess it's secured as it's the 3K91D for mini cooper 2003 right?
  10. #24
    May 2018
    Hey,
    I finally got the flash file extracted with Xprog.
    Made 2 loads just to make sure the tool is not wrong but seems good...
    Can you please tell me were do I find mileage and vin?
  11. #25
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by Thealchimiste View Post
    Hey,
    post exact original mileage and vin number
  12. #26
    May 2018
    Quote Originally Posted by jomberykaso View Post
    In miles it is: 217 117
    In Km after reading it via OBD on FVDI it is: 349 416
  13. #27
    Sep 2013
    your files are not good, i dont see mileage and i dont see vin number.
    mileage should be stored in addresses 0C00 to 0C7F
    Vin number should be stored in address 0E34
    * I also noticed that the first file you posted has a different Vin number than Vin you provided in your last post.
    Good luck.
  14. #28
    May 2018
    Should I try to read witout connecting xtal and reset pin?
  15. #29
    May 2018
    Default EUREKA RESOLVED
    EUREKA guys,
    I want to provide a clear understanding to anyone who is going to deal with the same situation of having mini cooper dash with µc 3K91D and wanting to update the mileage or VIN number by using Xprog chinese clone (as I've found many people after having solved their issue not providing a feedback that's not cool I think...).
    You need:
    1) Xprog box chinese clone (yes it works!!)
    2) The adapter named: HC(s)12 BDM adapter P/C: 1-002-0017 (it's coming with the Xprog kit if you bought it with the adapters see picture attached)
    3) A plug to connect Xprog to a 12Volt DC power source and the USB cable
    4) The correct pin connection (see pictures attached)
    5) Lunch Xprog software
    6) Select your device freescale in secured mode and, very important! what we want to read is absolutly not the flash of the µc which contain the program of the dash but what we want is the EEPROM of the µc, it is there where the VIN and Mileage are stored. For mileage it is from adress 0x400 to 0x470 and for VIN it is between 0x630 and 0x640. (I've attached my file)
    I still have now 3 questions if someone can help:
    1) Why are the last 5 16 bits of the last adresse of mileage storage area changed? Can I change it?
    2) Why is the VIN not complete, some caracters are not shown?
    3) How do I switch the unit from miles to Km is it in the flash memory?
  16. #30
    narkeleptk's Avatar
    May 2017
    USA
    EUREKA guys,
    Its a good idea to read eeprom first and save it. Then read flash and save it. Its not uncommon for flash to get damaged. Its good idea to have back up.
