Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
  1. #31
    May 2018
    yes if you don't want to touch the program of the flash it don't make sens to get the flash, but if you want to update the flash version you will definitely need to get it it.
    In my case it's only the eeprom area which interests me (VIN and mileage) as my SW version is already correct.
  2. #32
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by Thealchimiste View Post
    You don't understand what I'm trying to tell you. If you keep doing this work you will learn it the hard way one day no worries. good luck to you with your mileage.
  3. The Following 2 Users Say Thank You to narkeleptk For This Useful Post:
    d.zio (7th April, 2020), jomberykaso (3rd April, 2020)
  4. #33
    May 2018
    I got your point of damaging the flash by trying to read it but what I tell is that in my case I don’t have to read it do you agree?
  5. #34
    Fr
    Hi what sw hw is your dash thealchimiste ?
    Milles to km it's in eep .I didn't have the time to test sss perhaps milles to km can code with.
    I search a dump for HW 10 SW 20 to repair a dash also.
  6. #35
    May 2018
    Default checksum or not?
    Quote Originally Posted by Wod View Post
    It's mc912dg128a on MINI KMB, mileage it stored on area mentioned above but is also a pair of bytes within the flash that count also (mean can count anything from 0-255 without changing flash area, usually is close enough however to change just EEPROM area itself and is a counting hexadecimal matrix. All entries are summed together and as count goes up next higher byte is injected into start of matrix area and process goes on). I made a matrix counter in excel which can do the job, so feel free to upload the 2KB here and the amount of KM required. I won't share this formula because not one person helped me figure this stuff out on here. Can change also the whole VIN area, I tested last night but nobody help me with that either but I will offer to make a change for part of the VIN for you which is enough for good functioning.
    Hi Wod is there any checksum to do on the file after update or not?
    because I've updated my file on dash but after test only belt led gets on, I'think there is a check sum adjustment needed...
    Can you have a look on my file (I've attached original and new one)
  7. #36
    May 2018
    Quote Originally Posted by Freezzby View Post
    Hi Freezzby,
    So Where is this SSS you're mentioning?
    Mine is a little bit older it's HW09 and SW19.
    Attached is my flash, but I remember have been going through the forum and found the HW 10 SW 20 (see attached)
  8. #37
    Fr
    Hi google dis v57 there is a vmware image , I install it now ,it's a long time I didn't use this .I need a complete dump for HW 10 SW 20 my eeprom is bad also, I tried just with the flash but need a eeprom dump also,after I flashed a complete backup but not same hw sw dash working but I have errors that I can't delete them so need exact hw sw .
  9. #38
    May 2018
    Talking Dash done!
    Finally got all fixed,
    The flash data were not complete reason of having the dash not starting ( attached is the flash for HW09 SW19) with xprog.
    For the KM to Miles I've analized a combination of miles and km Dash EEPROM and changed the hex data that were uncommon on both sides and got it fixed. (attached you will be able to find the miles and km version, then you should understand how to go from one to another)
    Thanks all if you helped or if you were just looking for help
  10. The Following 3 Users Say Thank You to Thealchimiste For This Useful Post:
    Freezzby (7th April, 2020), jcdiag (11th October, 2022), Yhoni (21st April, 2021)
  11. #39
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Well done! !...........
  12. #40
    Fr
    Hi if I want to download it redirect me to login page for the eeprom km , eeprom milles file it download ok .
    Good you sorted out.
  13. #41
    Fr
    Hi here also HW10 SW20 pack with km and miles ,good initiative Thealchimiste ,I did less changes and I'm sure if have time to test more it's possible to find the exact address for km to miles .
  14. The Following User Says Thank You to Freezzby For This Useful Post:
  15. #42
    Oct 2018
    Macedonia
    Quote Originally Posted by Marens2007 View Post
    How far i get whit research to read mcu pin out for xprog is in attachment Attachment 700006.
    Is this the pinout for Mini R50 cluster's motorola MCU?
