Results 1 to 2 of 2
    Nov 2015
    Default BMW 325d EDC16C35 error 3F25, disabling possible?
    Hello, I have an e90 325d which is driving me crazy with 3F25 error (Charge Air Tube Monitoring) with limp mode. No visible leaks and actually I don't understand what triggers this error. Is there any way to disable the function totally? Thanks in advance
    speedy100's Avatar
    Athens
    Quote Originally Posted by m2312l View Post
    Hello, I have an e90 325d which is driving me crazy with 3F25 error (Charge Air Tube Monitoring). No visible leaks and actually I don't understand what triggers this error. Is there any way to disable the function totally? Thanks in advance
    Looking at my "log papers" i see that in two cases of 3F25 one was a loose pipe connector at the intercooler and the other was the Boost control pressure sensor.
    Good luck
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  3. The Following User Says Thank You to speedy100 For This Useful Post:
    PDXAutoworks (17th March, 2020)
