    fuzz1's Avatar
    Jul 2019
    Default c4 picasso gearbox ecu replace
    I am wondering if anyone can help me replace the ecu gearbox of a citroen c4 grand picasso year 2014 diesel 1.6L automatic
    Gearbox ecu number
    9662897580
    I am replacing with a second hand module not a new.
    Can it be a direct swap? Or should i reprogram to adapt the new ecu? Is it possible to swap some eeprom to get the car to accept the new ecu?
    I swapped and the car would not start.
    sim basta trocar que já funciona, porém é possível que seja um ajuste básico com scanner para funcionar fino.
    Jun 2016
    I've got some exprerience with this sh..it ... cut case in old module .. resolder all elements...
  4. The Following User Says Thank You to pawel7924 For This Useful Post:
    fuzz1 (31st March, 2020)
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by pawel7924 View Post
    Hi. Thanks for your help. Can you guide me as to what elements needs to be replaced? It's a real headache even the dealer can't find that ECU on their system
    Jun 2016
    resolder all, i think there is many cold ironing points, producer economise soldering operation ...
    I didn't exchange it ... but i thing you must change vin and make adaptation with diagbox (maybe modules must be virginize - i didn't know)
    fuzz1's Avatar
    Jul 2019
    Thanks will open the module once the curfew is off.
