    Jan 2019
    Somewhere between Continents
    Default 2005 Nissan Micra All Keys Lost
    Hello guys.
    Can anyone help me out with a 2005 Nissan Micra (I think its a K12)m with All Keys Lost?
    The owner got a original key from Nissan but they say they cant program because its too old...
    I tried to program with FVDI 2018, and i was able to enter the procedure and unlock the ignition (its those proximity keys / start systems) making the "programing procedure", but i allways get the red "KEY" light on...
    I got the PinCode (12 digits) from the glove box coding, and it seems to accept the pin.
    Procedure runs fine but there is no way i can get this to work... I allways have DTC P1611 than doesnt goes away...
    Is there anyway i can program the key directly into BCM / IMMO / ECU using FVDI 2018 or EEFI?
    i never made any of these nissan cars so this is new to me and i dont know really how to do it...
    If anyone can help i really appreciate...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
    castin's Avatar
    Oct 2015
    Im use Tango for this car by eeprom job. Check "key sensor" in ignition switch.
  3. The Following User Says Thank You to castin For This Useful Post:
    boxsport (19th March, 2020)
    Jan 2019
    Quote Originally Posted by castin View Post
    Thanks.
    Could i do this with FVDI 2018 tool i have?
    Do i need to read only the "Key Sensor" eeprom or do i need to read anything else?
    castin's Avatar
    Oct 2015
    Read eeprom from BCM (under dash board propably passanger side).
  6. The Following User Says Thank You to castin For This Useful Post:
    boxsport (20th March, 2020)
    Jan 2019
    ok. i will see if i can get the bcm in these days and will let you know.
    do you know if i can do this eeprom programming with fvdi or eefi+zed bull?
    I dont have tango..
  8. #6
    castin's Avatar
    Oct 2015
    If its PCF7936, then i help You. Post dump from eeprom and ID PCF7936 chip.
