Results 1 to 2 of 2
    Integy's Avatar
    Sep 2015
    Default BMW F32 - 420D xDrive- Encoding VTG Module
    Hello Members!
    I want ask about help with car from thread. I Need quick tutorial , how to code/write correct VIN to VTG module, after change for used one. I have ESYS OFC, and ISTA.
    On car have dtc :
    021908 Encoding: data invalid
    02190B Encoding: Transmission failed
    48097D Transfer box: Fault, clutch position known, no four wheel drive
    Mar 2019
    For coding you need ISTA but for change the VIN, yu need other Ecu Programmer like a Yanhua ACDP because is a used part. ISTA doesn´t re-write VIN number. Try with ISTA and post here te measured plans for see.
  3. The Following User Says Thank You to cubicar For This Useful Post:
    tyrystor (25th October, 2020)
