Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Mar 2017
    I copied in external programmer because FVDI 2018 cannot read data from the Skoda Octavia II 2012 dashboard.
    data in the photo read from the ECU 16u34 and saved a new dashboard. Red color:
    - CS 7 bit?
    - power class
    - new key.
    Original key 3cdbd72a saved in das 1z0920843S and ecu 16u34. I added it manually.
    Can bit 7 be read from this key?
  2. #17
    kuebk's Avatar
    Feb 2016
    Wrong, ECU has 6 bytes out of 7 byte CS. Last byte in ECU is always 00.
  3. #18
    Oct 2014
    Netherlands
    If you use data extracted from ECU then you have only 6 CS bytes.
    Keys are programmed with 7 CS bytes, and you don't know this 7th byte.
    Also it doesn't matter because you upgraded to a VDO NEC cluster which uses 12 bytes CS.
    So fill in all immo from your ecu, also the 6 CS bytes, then add 6 random bytes to make it 12 in total.
    Then you *must* learn new transponders to match the cluster.
    That's it.
  4. #19
    Oct 2014
    Netherlands
    I see some problems:
    - Your MAC is wrong. It should be: F2983232
    (AVDI has bugs)
    - Your AVDI is not allowing you to enter 12 CS bytes, you have either selected wrong cluster type or it is a buggy version of AVDI.
    And remember, you must adapt new transponders in this situation!
    Rgs H2Deetoo
  5. #20
    Mar 2017
    Everything works thanks my friend H2Deetoo
  6. The Following User Says Thank You to mcaris25 For This Useful Post:
    H2Deetoo (6th October, 2022)
  7. #21
    Supas's Avatar
    Jun 2020
    I'm glad you fixed it! What H2deetoo knows is incredible !!! It helped me a lot !!!
    Sorry I'm asking here ... but they talk about power class and maybe you can help me .... I'm trying to locate in a VW G6 marelli dashboard with NEC + 95320 part number 5U0920830A the power class in the eprom ... I think in somewhere in the eprom is unencrypted ... what is encrypted is the CS, the rest I don't think ...
    Do any of you know the address on the Power Class eprom?
    Thanks and sorry for the inconvenience
  8. #22
    Home
    Keep in mind, English is not my native language.
