Results 1 to 5 of 5
    Jul 2010
    FRANCE
    Default Component protection on J519 #09# A6 2005 6N
    Hello Dk's,
    I've in my workshop a Audi A6 76N 2005.
    I must change the Elv with used. I programed it manually.
    The keys was not programed. When I want programed it with my AVDI the soft can't open the canal . I must wait 300 seconds but no work. I think that the défaut in #09# protection component in this. I my AVDI I can't remove it in this module.
    Do you have a solution to offer me because i spent a lot of time and no way to start the key learning procedure.
    Aivis3's Avatar
    Sep 2016
    Latvia
    Easy way is read/Write ELV with Xprog. China Xprog working too.
    If helped - "Thanks" and "Reputation" please
  3. The Following User Says Thank You to Aivis3 For This Useful Post:
    Col19 (9th November, 2022)
    Jul 2010
    FRANCE
    Hi Aivis3,
    The original elv was the eeprom in all FF.
    I must write CS1,pin,MAC ans VIN manually.
    I did not find the CS2 so I put FF.
    The problem is that I have 0 key programmed and that the procedure does not start. Each time the channel does not want to open. I think this comes from the defect I have in J519 # 09 # regarding the protection of components.
    Apr 2013
    Swiss
    Hi, solved your problem? If you are still working on this problem I can try to help you
  6. The Following User Says Thank You to Cristianbomberos For This Useful Post:
  7. #5
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by durdur View Post
    Hello Dk's,
    what was wrong with the orignial one because i never did see one with all FF unless some one before you did mess with it
    like Aivis3 does say you can clone them very easy, but if needed upload eeprom from ori ESL and i will give you all data needed
