Results 1 to 12 of 12
    Nov 2013
    syria
    Default fiat punto 59f.m2 immo off
    fiat punto 59f.m2 need immo off plzzzz
    full flash +eep via fvdi
    Romania
    fvdi can make it virgin
  3. The Following User Says Thank You to cristinuz For This Useful Post:
    thaeerkh (23rd March, 2020)
    Nov 2013
    syria
    if i made it virgin what the next steps
    Romania
    Put it on the car and should start
  6. The Following User Says Thank You to cristinuz For This Useful Post:
    Nov 2013
    syria
    thank you i will try
  8. #6
    Nov 2013
    syria
    org ecu is damaged this ecu new and used one
  9. #7
    Romania
    I don't understand what you mean
  10. #8
    Nov 2013
    syria
    the old ecu is damaged this stepes can be done with used ecu
  11. #9
    rafal's Avatar
    UK - PL
    use manual of fvdi and you will do ............................
    use google and you will find all what you need
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following User Says Thank You to rafal For This Useful Post:
    thaeerkh (26th March, 2020)
  13. #10
    Romania
    Yes it is possible, ecu used, virgin Eeprom, put on the car
  14. The Following User Says Thank You to cristinuz For This Useful Post:
  15. #11
    Nov 2013
    syria
    i made it virgin but the car not work old ecu 5nf new ecu 59fm2 is that problem
    i still have immo signal problem
  16. #12
    Sep 2013
    Fvdi works perfectly. I did it in my cars last week. Iaw 59f m2. Virgin it . It takes about 2-3 minutes to read the eeprom then 2-3 m tooto vurginse it.after put key off on then start car.good luck
