Results 1 to 4 of 4
    Oct 2015
    Question FSC code for BMW CIC retrofit
    Hello guys maybe sommeone can help me :
    I have install an used CIC in my BMW E90 wich come with the old CCC.
    I write my VIN to the new CIC and make all FSC code for it.
    When I try to write the FSC code with FSTOOL 2.0.1 only 17,1B and 19 are accepted. With 6F, 9B an 9C I have error 10802 in FSTOOL.
    Can anyone help me please ? I read in some forum that my FSTOOL is too old I need FSTOOL 2.2 how to update it ?
    Thank you :-)
    If I help you don't forget thanks button
    Mar 2011
    Vilnius,Lithuania
    you can use navi with 19,19,1B and forget about others fsc because you don't need them.problem is not in fstool but in your fsc templates I think
  3. The Following User Says Thank You to xyznia For This Useful Post:
    memet99600 (24th March, 2020)
    Oct 2015
    Quote Originally Posted by xyznia View Post
    Thanks for your answer, but in the future I want to install a combox and use bmw app so needed to add 9C. The template I use I change only VIN so I don't understand where is the problem.
    The navigation works perfectly :-)
    Mar 2011
    Vilnius,Lithuania
    then simply buy fsc set generated with proper tools it will cost you 20-30eur I think
