Results 1 to 7 of 7
    Mar 2019
    Earth
    Default CARPROG DIY ADAPTER FOR EEPROMS
    Hi guys.Since i cannot use carprog for reading eeproms besides the clip adpater i thought i can make my own adapter.I used this schematics,works just fine for 95xxx and 93cxxx but..........with 24 and 25xxx type eeprom it does not want to read it ,it only shoes 0000000000 everywhere.Can anyone help me ? is there anything i need to modify?
  2. The Following User Says Thank You to 12manux For This Useful Post:
    ecufix (1st June, 2020)
  3. #2
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by 12manux View Post
    Hy, look to eeprom were must be first pin to conect, can you rotate.
    Wbr
  4. The Following User Says Thank You to catalinosonesti For This Useful Post:
    12manux (23rd March, 2020)
  5. #3
    Mar 2019
    Earth
    Read the post.I have succesfully read 93cxx and 95cxx ,but with 24cxx doesn t work.Is not a problem of contact or rotation,is something wrong with my wiring i guess
  6. #4
    Mar 2019
    Earth
    Ok it didn t work because i did not plug the 12v adaptor.For those of you who want to make this adapter,is very handy and i higly suggest you to make one of your own.
  7. The Following User Says Thank You to 12manux For This Useful Post:
    PocketHero (23rd March, 2020)
  8. #5
    Jan 2010
    Trstenik - Thun
    For read and write 24cXX not need connect external 12V power supply!
    Sent from my JSN-L21 using Tapatalk
  9. #6
    Mar 2019
    Earth
    This is what i knew ,but aparently if i feed 12v power it works just fine .God knows why
  10. #7
    Jan 2010
    Trstenik - Thun
    Just because it is not good hardware .Bad components.
  11. The Following 2 Users Say Thank You to mikroel For This Useful Post:
    catalinosonesti (7th May, 2020), electronistul21 (2nd April, 2020)
