Huawei Honor 9 keeps restarting after screen replacement
Results 1 to 3 of 3
    Member catalinux's Avatar
    Jun 2010
    24
    Downloads
    10
    Uploads
    Default Huawei Honor 9 keeps restarting after screen replacement
    Hello guys,
    I am a do-it-yourself kinda guy, but not that much into phone repairing, though a display replacement in my opinion was not such a big deal. It turns out that i messed up my phone.
    Let me give you the entire story so you can direct me to a final solution.
    1: Huawei Honor 9 6Gb with 129 Gb storage - brilliant phone (my humble opinion)
    2: it already has 2 years with me
    From time to time it was restarting by itself but did not bothered me at all, still it was running well.
    3: I damaged my display and bought a new one (not original-cheaper -1st mistake)
    4: Using tutorials started to dismantle the phone - all good until battery, well, there i kinda buckled and bended the battery)
    5: all back together and since then I have the following symptoms:
    - appeared some lines on the phone and then it restarts 6-7 times in row
    - if i manage to start it up, if a open 2 or 3 apps, or the camera it starts rebooting.
    - now it can not be used any more sometimes it starts sometime not.
    My question will be:
    I found a kit of display and battery original just need to put back the mainboard and the cameras and back panel.
    - Is this problem from the mainboard? loose connection made by me? battery issue? display issue?
    I want to ask if i should buy the repair kit that includes the battery and the display, or not? (when mounting I did not apply any grease on the mainboard)
    Thank you very much!
    Cata
    kappa1's Avatar
    Apr 2013
    RO-IS
    4,571
    Downloads
    33
    Uploads
    Hi first try to put another battery ! if problem continue maybe you need to put another soft in phone
  3. The Following User Says Thank You to kappa1 For This Useful Post:
    catalinux (25th March, 2020)
    Jun 2010
    24
    Downloads
    10
    Uploads
    Hi all,
    Thank you for support, i bought a original repair kit including battery and display, it works like a charm. Don't buy non original display.
    Now I can't find how to install the Google Play Store
