I have a golf mk 5 GTI with AXX engine. I swapped it to a CDL engine from an Audi S3 8P 265HP.
Now, i have the following problem:
If i put the ecu from cdl, car doesnt start. So i do immo off and car start.
Now the CDL audi ecu is coded for a manual gearbox and 4x4 (all wheel drive)
When i try to code it to 2wd it always gives me an error. I try with geniune odis, vcds, abrites and vcp. It does not accept the code.
Manual gearbox to dsg will accept. I think the coding is in the eeprom( correct me if i am wrong)
Can someone help me code this to 2wd in the eeprom?
I attach the eeprom file what is now inside in the car.
