finally is work with digiprog!!!!!! thank you for help @drpeter and @jomberasko, last help, i attahed the 95128 file, please can you make 96000 km? originaly 143000 circa thank you very much
Ciao Jacopo, potresti spiegarmi perché hai dovuto fare il cambio dei Km per favore
ciao
grazie
Jacopo89 (27th March, 2020)
because the abs module was changed, and if you can't change the km value in acordto dash the bigger km appears
sorry JomberyKaso i was reply to italian user, i'm testing in afternoon, i think i have a problem with digiprog (only instrument that write and read for me) i write the file ok but i i try to read it the file write digipro read a file 17 kb not 16kb, i try to open with hex editor and i see the last 6 line al FFFFFF, what i can do?
You need to buy a real eeprom programmer
hi, abs done, ecu done, and dash done, but km jump back to 143642, i try to connect the dash with 96.000 km (attacched file of dash and ecu, abs is your file now but is not conected) without connect abs (only ecu), but km still jum back (sothe problem is not in abs file), whats wrong?
Upload also your ori files
This is edited files
Sorry i wanted to say original files
I think you forgot to edit some lines in dash file, i see 96000 in ecu
You see wrong value in dash ?
