mcday (31st December, 2022)
Hi members , I have a problem with light rear left (tailīs vehicle) Range Rover Evoque 2016 (break and left turn) donīt work, I buy a BCM used the same number! I put in the car push the button warning lights, and all turns break stay OK, but the vehicle stay "dead" . I change D-FLASH dump in new used one using the original of car, the error came again the original dump is corrupted, i need help to change BCM or repair the dump,
NUMBER BCM = GJ-14F041-AB
I read using VVDI
note: Like the same FRM in bmw
THANKS!!!
problem solved....
what tool do you have for this car?
you dont have to change anything....the ori bcm...works....you need a tool for this...
pm and i will tel you
and ofcourse.press thanks and rep...
if you read exactly why i have negative,you will se...
i dont whant money for the info..like another guys from this forum...this is forum for help info and make the jhobs more easy...if for you its to much to press thanks....
all my info..if i know its for free...
your opinion if its not corect..im no intrested..
Meat-Head (4th October, 2022)
an the solution its to make reset bcm ....with the launch (update on day) or use JLR
you have short in bcm,but in software,not hardware...
and jhobe done...
Jexus86 (19th April, 2023), Meat-Head (4th October, 2022), todorecambio (10th April, 2023)
reset bcm for me not working...
