your first DW map is at address= D1A3C, 8x16
If you need i will upload map pack to find maps easy.
IF I HELP YOU PUSH THANKS AND REP BUTTON
davorsule (27th March, 2020)
here you can see two of seven dw maps,
also you can use map packs, but then you will never learn finding map skills
familiozo (27th March, 2020)
Look for some maps in 2D view (winols).
Here is map pack.
here is what you need ok hit thnx and reputation pass in PM!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Thanks for the above files.
I've got a question..
I'm looking to reverse engineer my Air Fuel Ratio and Maf mg/s to output the Fuel Injection quantity.
So you can calculate AFR by the following formula -
Maf (Mg/s) / Fuel Injection quantity (mg) / AFR (your chosen fuel is most efficient at) * 10
I'll give an example.
(500(a)/28.78(b))/14.7(c)*10 = 11.8(d)
Which in my case is the value I want to reverse engineer.
I want to work out what the value of B is, if I know the values of a, c and d. Something that also might come into play is the rpm... 1750(e)
It there anyway that I can get calculate the fuel from the AFR / MAF in the same manor?
(this is probably quite an easy question, but it's late and my brain isn't working)
Formula you wrote isn't good method to calculate injection.
Must presume and test which AFR value will be the best for engine. Factory adjusted maps are usually the best,
you could compare, but it depends what you want from engine, in which altitude is engine running mostly and other factors.
Try about 16,6 - 17,1 at higher maf,rpm valus.
Then calculate lambda from adjusted afr and at last iq_limit_with maf or map.
Simply first calculate lambda from adjusted afr and then iq with formula.
lambda= AFR/14,5 or 14,7?
lambda=(maf/iq)/14,5
AFR= maf/iq
iq= maf/(14,5*lambda)
I can send you excel table which I made, IF YOU CLICK REPUTATION!
aparni198 (31st March, 2020), familiozo (28th March, 2020), mmartin191 (28th March, 2020)
Many thanks!
