Results 1 to 7 of 7
    Mar 2020
    Default Toyota rav2002 starts doesnt crank
    My toyota rav4 2002 suddenly stopped working. It starts, however doesnt crank. After getting it diagnosed, it throws a b2796.
    Do I have to reprogram the key, or could it be just a problem with the fusebox?
    Jul 2013
    yorkshire
    If no crank how start?
    DK Veteran teuton's Avatar
    Mexico
    Quote Originally Posted by frisavic View Post
    Maybe you miswrote and it'sa crank/no start??Or are you able to pushstart the engine?
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  4. The Following User Says Thank You to teuton For This Useful Post:
    narkeleptk (27th March, 2020)
    narkeleptk's Avatar
    May 2017
    USA
    Not sure about the rest of the world but in the states the immobilizer for these are in the ECU, So the code "B2796 : No Communication In Immobilizer System" would lead me to suspect that your key is dead and needs to be replaced or your having issue's with the key antenna and/or key amplifier near the ignition.
    Jul 2013
    yorkshire
    why no reply from poster?
    Meat-Head's Avatar
    Quote Originally Posted by autoden View Post
    Arresred for breaking lock diwn rules???????
    Mexico
    Did you "playing" with underhood_fusebox adding some fuses ?
    Check for this fuse in the underhood fuse box.. If is installed.... remove it
    Regards..
